what years and what trucks did the nv4500 come in? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2007, 06:21 PM   #1 (permalink)
Member # 90081
i'm lookin for a nv4500 can you help me out?
J_v8toyota77 is offline   Reply With Quote
Old 10-23-2007, 06:33 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
88 and newer IFS trucks 3/4 - 1t
any solid axle truck would have gotten the 465/205
Old 10-23-2007, 07:29 PM   #3 (permalink)
Member # 90081
465? 205 transfor case right wahts the 465?
Old 10-23-2007, 07:31 PM   #4 (permalink)
Member # 41764
The 88-89's IFS HD's got the SM465 as an option IIRC and at some point there was a Getrag 5 speed avaliable too. The 4500 was only in 8 lug 3/4 tons and 3500's. The 6 lug 2500's with a stick would have an NV3500.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
JasonPayneMemorial
bggrnchvy is online now   Reply With Quote
Old 10-23-2007, 07:38 PM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
granny gear 4 speed no o/d
very very tough.
kick ass for wheeling.
slow shifting and huge shifter.
great tranny, i love mine, just wish i had the od.
Old 10-23-2007, 08:55 PM   #6 (permalink)
Member # 80727
Did all 465's have 205s behind them? I thought my stepside had a 208...
1994 Isuzu Trooper: OM617/W56/toybox
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is offline   Reply With Quote
Old 10-23-2007, 11:40 PM   #7 (permalink)
Member # 100689
My 84' K5 also has the 208. 1980 was the last year of the 205.
Jonathanjay743 is offline   Reply With Quote
Old 10-24-2007, 08:51 AM   #8 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
THe 4500 was also available in half-tons, I know of 2 locally that I know of.
'91 k3500, 454, 4speed, 42" R-1's no lift
'97 z-71, 3" BL, 38" tsl radial, 454/th400
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
34/10.50/16 ltb
Red Chevy is offline   Reply With Quote
Old 10-24-2007, 09:03 AM   #9 (permalink)
Member # 21453
Halfton with a diesel perhaps?
The gm version of the 4500 had several flavors that I am aware of.
93-94 had a remote located slave cylinder pushing on a manual fork...similar to a hydro setup on a older nv3500 or a sm465. It also had a lower first gear...6.37 or so I belive. 95 went to a 5.76 or so first fear and in 96 I believe they went to a mainshaft mounted slave cylinder.
I could be wrong here...but if you search around some you can find a fairly definitive source.
As far as strength goes...its in the ballpark of the 465. The 465 is a bit stronger but has wider spacing and missing the overdrive 5th. The 4500 originally had a problem with the 5th gear locknut backing off under high loads. The (brass if i remember right) synchros also require special fluid and are the only other weak point I know of. I tend to see them go for 4-600$ used.
Kilborg is online now   Reply With Quote
Old 10-24-2007, 09:36 AM   #10 (permalink)
Member # 21408
I have heard of 1/2 ton trucks with the NV4500 and 9.5" SF rear axle, very rare and required a certain combination of some sort of trailer towing package or the like.
6.2Blazer is offline   Reply With Quote
Old 10-24-2007, 10:27 AM   #11 (permalink)
BajaBilly's Avatar
Member # 13128
Yep, had one here at the shop the other day
[QUOTE=born loser]'crawlin's sooooo Y2K.:laughing:
thats why its always fun wheelin w/ bill. theres no spottin or pickin lines.
Belt-in, put a brick on the gaspedal, and FTW.:flipoff2:
[/QUOTE]
[SIZE="5"][FONT="Arial Black"]WWBBD?[/FONT][/SIZE]
Anger is a gift
BajaBilly is offline   Reply With Quote
Old 10-24-2007, 10:36 AM   #12 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
Yep that is the combo my buddy has, 9.5 rear, 4500, some sort of factory towing package. the other one I spoke of is a 4-speed, sorry.
34/10.50/16 ltb
Old 10-24-2007, 08:03 PM   #13 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
dude, the 205 went all the way to 91.
yes the 203, 205, and 208 all came behind the 465, the 241 could be placed behind it if desired by using the 208 adapter housing [i belive]
Old 10-25-2007, 12:23 PM   #14 (permalink)
Member # 19509
My 93 light 3/4 has a 6.2 and a NV4500 in it.
XJCRAWLER is offline   Reply With Quote
