Member # 54792
GM TBI gurus, projunktion swap
quick explanation:
What I have is a 87 chevy 3/4ton, this is my plow truck/ work truck. The truck had a TBI 350 in it till I blew it up (pulling my boat). SO I decided to put a 454 I had sittin in the garage in its place. I still wanted to keep the truck fuelie so I installed a Holley Projection 4 barrel fuelie system. Seeing the truck is already a fuelie I figured I wouldn't have to hook up the holley fuel pump and I could just run off the factory chevy in-tank pumps. I removed the factory TBI pieces but I left the wiring harness in place in case I decide to go back. Heres the problem I came on last night -When I turn the key into the on position the stock fuel pumps (either of the two tanks) don't turn on. My question -Is there some sort of sensor/hookup that sends a "feedback" signal to the factory computer that tells the fuel pump to kick on ? ANd this needs to be hooked up in order to get fuel? ANy info related to this would be appreciated Thanks Matt |
first you shoulda kept the gm tbi.... second the computer controls the pump via the fuel pump relay.....wire up the pump the way the holly instructions tell you too.... You may well need the holly pump too, personally I'd go back too the gm stuff... All you need is the proper throttle body and computer chips for the 454
Kevin [URL="http://www.pirate4x4.com/forum/showthread.php?t=567624"]My build thread[/URL] Killed the S-10 n2 jeeps now |
Member # 27377
I am far from an expert on this, but I will try. I believe there is a fuel pump relay that recieves a signal from the computer when you turn on the key. There is an oil pressure switch on mine, The oil pressure switch turns off the fuel pump when there is no oil pressure. Not sure if yours is the same, but mine is a 1990 3/4 ton suburban 454. Hope this helps.
78 Blazer, Dana 60/14bolt, crossover steer, front and rear ARB's, beadlocked 39.5 Irok's, 465/205, smallblock 400, TBI. "...........and that was without a single drop of rum!"- Captain Jack Sparrow |
Member # 37184
The GM ECM turns on the fuel pump for two seconds, via the fuel pump relay, when you turn the "key" on, but don't start the engine.
That's test "one" to determine circuit functionality. If that's a go, then the ECM again, via the fuel pump relay, turns the fuel pump on while the engine is cranking (ECM senses this), AND the ECM is receiving ignition pulses. It's possible for the relay to be bad/incorrectly wired, and still have fuel pump run; however, the pump would not come on untill the oil pressure builds high enough to close the pressure switch (part of the oil pressure sensing switch). Again, the ECM needs to sense ignition pulses at the same time.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's. |
