TBI Problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-24-2007, 03:51 PM   #1 (permalink)
Member # 91839
TBI Problems
so i have a 91 k5 350 TBI and i am having some serious issues with the engine it will start and idle fine and sometimes rev up fine but whenever i put a load on it, let out the clutch and try to accelerate it starts to cut out and has no power. and other times when i try to rev it up at a stand still it sounds like its missing and backfires and wont go above 3000 RPM's and i've already check all the plugs and distributer i tried a new fuel filter, and checked all the wire connections and vacuum lines. Anybody have any other ideas or have this problem any help would be apprieciated thanks.
clevelandcruiser is offline   Reply With Quote
Old 11-24-2007, 06:42 PM   #2 (permalink)
Member # 98511
ck fuel preasure-"t" in gauge by fuel filter-should be 9-13 psi running.
mmk5blazr is offline   Reply With Quote
Old 11-24-2007, 07:02 PM   #3 (permalink)
Member # 84557
whats timing at?
dick_landy is offline   Reply With Quote
Old 11-25-2007, 02:36 PM   #4 (permalink)
Member # 91839
Well i dont think its the fuel pressure because the fuel pump is pretty new but i will still check it out. and im not sure what the timing is set at but i didnt think it would idle very well if the timing wasnt right
Old 11-25-2007, 06:50 PM   #5 (permalink)
Member # 84557
it will idle ok but when you floor it, it will fall on its face. i got a smokin deal on a truck once cause it had no power. turned out the distributor hold down was loose and the timing was 10* retarded.
Old 11-25-2007, 10:03 PM   #6 (permalink)
Member # 91839
interesting i'll check that out. i was doing some reading and i think it may have to do with the EST/ESC system
