th 400 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-28-2007, 03:50 PM   #1 (permalink)
Member # 68123
th 400
Changed the fluid and screen in my th400 a few weeks ago. I haven't ran it since the service. I cant remember how much fluid I put in exactly. Fluid is at the top of the hot full mark while idling. Transmission ran fine before. Now there is fluid coming out around torque convertor at high RPMS. Anyone have any suggestions to what the problem is or any solutions.
rdnek8 is offline   Reply With Quote
Old 11-28-2007, 04:06 PM   #2 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
front seal?
1972 GMC Submarine
383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez
Inclined to brute force attack a 70* incline with a Quadrajet
1997 GMC K3500 Suburban
454 / 4L80E / HP60 SAS / PROJECT TOWHOE
florida4x4 is offline   Reply With Quote
Old 11-28-2007, 05:58 PM   #3 (permalink)
Member # 73673
sounds like a front pump bushing to me thats what happend to my 700R4 when i blew her up puked all the atf out the front ...
Stout Racing is offline   Reply With Quote
Old 11-28-2007, 06:07 PM   #4 (permalink)
Backncardr's Avatar
Member # 24747
Make sure the trans breather vent is clear and not blocked.
Backncardr is online now   Reply With Quote
Old 11-28-2007, 06:28 PM   #5 (permalink)
Member # 68123
The vent tube is not blocked and is clear of any obstructions. It is not a lot of fluid just pouring out. It is a stream about the size of a pencil lead and it only happens above ~ 3500RPM. I was just wondering if this a symptom of too much fluid.
Old 11-28-2007, 06:30 PM   #6 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
seals fucked.
start there.... if you get to the seal... well, you gotta pull the converter
if you find the front seal the bad part, change it... if you pull the converter and the bushing has seized to the hub, replace the pump, because it probably wont hold a new bushing, either.
start at the seal.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is online now   Reply With Quote
Old 11-28-2007, 06:33 PM   #7 (permalink)
Backncardr's Avatar
Member # 24747
Could be. The fluid level in the has to be even with the pan rail when full. Drop the pan and check the stick against the pan rail on the case-remark if necessary. If ok time for a new front seal and/or new pump o-ring. Be a good time to replace the pump bushing as well and check the surface of the torque convertor hub for scoring.
Old 11-28-2007, 06:42 PM   #8 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
also watch for cracks on the front of the converter. they can cause weird leaks.
1972 GMC Submarine
