ECM Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2007, 11:39 AM   #1 (permalink)
T_Spurger's Avatar
Member # 99760
ECM Question
All of this is for a 96 Chevy 4x4. Was the 4L80E controlled the ECM or a TCU? If it was the ECM what all is need to swap in a 4L80E in place of a 4L60E? Is there any rewiring to be done? Where is the Vss suppose to be placed?
Tim
1996 Chevy Ext. Cab Vortec 350/4l80e/np205 SAS Dana 60/14 bolt FF 37 x terrains
T_Spurger is offline   Reply With Quote
Old 12-04-2007, 05:03 PM   #2 (permalink)
Member # 37184
Not sure about '96, but in '95, the PCM controlled the trans, whether it be a -60E or a -80E. The harness for the -80E may a little different, or maybe the same for both trans, but some wires not used with the -60E apps. The -80E uses two sensors--one to tell the PCM the tranny input RPM's, and one (a VSS) to give vehickle speed.
You need to get wiring diagrams for both apps and compare them.
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's.
Bubba_Jeep is offline   Reply With Quote
Old 12-04-2007, 05:49 PM   #3 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
You need to change the wire harness plug for the transmission and add some wires. And you need to have the PCM (computer) tuned for the 4l80. I am unsure if that PCM can just be flashed or needs use something like tunercats. The later ones can be easily tunded for the 4l80. The VSS needs to be placed in the transfer case, thats were it's at stock. You will also need to modify or get a different trans cross member as the 80 is longer as well as modify the driveshfts.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
