Member # 104571
87 chevy dully 4x4 can it converted ?
ok well i have come cross a 87 chevy dully 4x4 and want to know if i can convert it to a raguler 1 ton 4x4 with out changing the axles ? there is just something about the crew cabs. i would love to make a swb crew cab and adventurly put a duramax in one.
Member # 104571
does this work front and rear. i havent even got a chance to look at the thing yet but i just remember that dully front rims look like they are front wheel drive off set like the axle is wider then i standerd 1 ton
Member # 343
On the front you'll have to simply swap to SRW hubs (single rear wheel).
You need to read this FIRST!... http://www.pirate4x4.com/tech/billav...ble/index.html |
Member # 68512
you simply run srw hubs on the front 60, and srw hubs on the rear 14b. you might have to run srw brakes too on the 14b
89 s10, flogged regularly 94 burb, tow rig |
Member # 104571
thanks. now does any one know if i can make this long bed into a short bed? im thinking i might run into some problems with the frame rail diping down for the cab or will i not have move it that far forward?
Devout Newbie Hater
oy... sounds like a newbie post...
break out the sawzall, cut the frame, and shorten it. oh.... stick it back together with bailing wire and bubble gum.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
Member # 104571
im talking about the front hanger mount of the leaf pack if i move it forward into the section of the frame that rolls down it will also roll my leaf pack
check out my friends at boneyardfab.com |
#10 (permalink) | |
Member # 87457
What are you trying to do here?
2000 Yukon Denali hidden inside a 1997 Yukon body :D SAS, hp d44, 14ff, 5.13s, 38s..... |
Devout Newbie Hater
Oh, hell!
i figure it out! he wants to know how to move the spring hangars forward to preclude cutting the frame off. this would give lift. just cut the rear part of the frame off, right... sure go ahead and do it.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! Last edited by Grumpy_old_fart; 12-17-2007 at 08:55 PM. |
#12 (permalink) |
Member # 87457
Oh!!! I understand now!!!
I'd like to see this done too.... Be sure to take lots of pics, good luck! lol
#14 (permalink) |
Member # 87457
I'm not too familliar with crew cab frames but if they are like most of the other chevy frames then I think this can be done without too many problems. You would probably have to do a shackle flip to keep your springs at a reasonable angle, but expect quite a bit of lift from doing this also. It would actually be a pretty cool project. Just take good pictures along the way
#15 (permalink) |
skullfuckery
Member # 29016
its not a bad idea, for a capable welder and wrech head. it is a bad idea if you have no idea of how to even cut it out or are asking questions like this.
as for the rear axle you will be better off just getting a srw 1t rear axle becuase of all the brakes and width situations. a srw 14bff is 67.5" @ wms your dually axel is going to be either 73 or 63" @wms, while you can make the srw hubs mount dirrectly the brake mounts WILL NOT line up and you have to weld and remount all the brake stuff. if you get a 14b out of any 1t 2wd or 4wd it will be a dirrect bolt in and everything will be ready to use.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#18 (permalink) |
Oilfield Trash
Member # 64526
Spring pads are closer together on a 1-ton, it uses hangers that hug the frame closer to give clearance for the c&c rear that is narrow.
'91 k3500, 454, 4speed, 42" R-1's no lift '97 z-71, 3" BL, 38" tsl radial, 454/th400 '97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool, 34/10.50/16 ltb |
#19 (permalink) | |
be cool, baby
Member # 17896
The rear wheel openings are bigger, so you will need to get a standard bed too, not just take off the flares.
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly |
#20 (permalink) |
Member # 98655
How short do you want to make the bed? There are threads in here where guys have put crew cabs on standard cab 8' bed frames and ended up with about a 5' bed. That wheelbase would be 131". If you wanted a 6' bed, I am not sure your spring hangers in the rear are gonna end up on a straight part of the frame. It would seem that your rear spring hangers would end up in the kickup area of the frame and that would have to be addressed and modified to achieve your goal, assuming you wanted straight frame rails out behind the cab. Type in crewcabs under search and see what you can find. should be plenty of info to give you an idea of where you are headed.
#22 (permalink) |
Member # 7648
I just built a 91 dually for a guy that had the dana 70 in the back.
I have a 97 dually with a 14bolt in it. But I would bet it's a 70 for that year. But if you can't identify the rear that's in the truck no need to proceed. should be a walk in the park. |
#23 (permalink) |
Member # 100166
While that's true of a cab-and-chassis dually axle, the dually pickup axle is much wider. Therefore, even if it is a 14 bolt (which I highly doubt; likely a D70 as others have said) the axle shafts would be different length, etc. Even with a cab-and-chassis rear, the brake backing plate flanges would need to be moved to accomodate SRW brakes. Anyway, best bet here is to swap the D60 hubs to SRW up front and find a SRW one ton 14 bolt (must be one ton for 40.5" perch width) and be done with it. Don't bother trying to modify the rear you have now.
Good luck to you, Joe S. |
#24 (permalink) |
Dude, this ain't the place to be throwing around newbie questions on shit we've been doing ourselves, and talking about, for years!! Just give me your CC dually, get yourself a SRW truck, and move on. Also if your desire is to have a CC, shortbed, SRW, 4x4.....well, forgive me for sounding like a broken record here, but fuckin' search!!! Search first, ask questions later.
....Chris '94 GMC Sierra 2wd, 5.7, NV3500, 3.73, 6" RCD, 33" ProComp, stereo '95 GMC Sonoma 4x4, 4.3, 4L60e, 203/205, D60's, 4.10, 38" SX's on H1's '04 Dodge Ram 4x4, 5.9, NV5600, 273, 3.73, 3" ProComp, 22.5 Aloca's, some goodies [color="#FF0000"][SIZE="5"]"NO!! I don't want to press 1 for English!...."[/SIZE][/color] |
