swaping knuckles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2008, 06:03 PM   #1 (permalink)
old school 1's Avatar
Member # 62655
Exclamation swaping knuckles
qwestion i heard that dana 44 knuckles will fit a 10 bolt front axle ?
old school 1 is offline   Reply With Quote
Old 01-05-2008, 06:37 PM   #2 (permalink)
Member # 87457
yes.....but they differ. IIRC the flat top D44 knuckles had it so the tie rod dropped in from the top. The later ones went from the bottom. So do the 10 bolt ones.......
2000 Yukon Denali hidden inside a 1997 Yukon body :D SAS, hp d44, 14ff, 5.13s, 38s.....
Gearhead 1990 is offline   Reply With Quote
Old 01-05-2008, 06:55 PM   #3 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
yes. i dont know exactly when they switched the taper direction but you need to pay attention that you get them to match.
Old 01-06-2008, 09:54 AM   #4 (permalink)
Member # 62655
Talking knukles
thanks guys ill look at tie rod end the problem is a buddy has a 10 bolt in a wrangler and wants me to weld a drop pitman arm on the pass side kuckle only problem is the flange is real small dont want it to look shitty but i have a spair dana 44 with flat tops both sides we where going to swap out then i would have more surface of welding and strength???
Old 01-06-2008, 10:39 AM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
DO NOT!!!!!!!!!!!!!!!!!!!! WELD TO THE KNUCKLE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
it is cast iron and will not hold.
Old 01-06-2008, 01:17 PM   #6 (permalink)
Member # 86392
i ran into same problem with my bros rig, swapped a knuckle and ended up with two tapers, well its a good thing he's runnin high steer now.
77 oneton is offline   Reply With Quote
