Clutch problems..... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-01-2002, 12:14 PM   #1 (permalink)
Member # 5146
Question Clutch problems.....
The Z-bar linkage keeps coming off the pivot ball that is on the block when the truck gets flexed at all. Do they make longer pivot balls? Anybody else have this problem? I am thinking about converting to a hydraulic clutch any suggestions on this route?
Mr. Infinity is offline   Reply With Quote
Old 07-01-2002, 04:23 PM   #2 (permalink)
Jackstand Wheeler
4Bangler's Avatar
Member # 12152
Hydralic all the way, get a bellhousing from an '84 & up Blazer or bore the index on a late '80's early '90's 4.3L T-5 or V8 car bell. Use a master and slave from one of those too, plus the right fork and all that jazz. I used to be able to open the driver's door on my '77 3/4 ton by pushing in the clutch, plus I could change the fuses by pushing the carpet aside and jumping down to the ground, inside the truck (it was on 38's and I'm 5'8")
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run.
4Bangler is offline   Reply With Quote
Old 07-01-2002, 07:20 PM   #3 (permalink)
mj
Member # 1919
are you on ck5 as well?
there is great info on the hydro swap there.
even a few that have photo documented the clutch master install on the earlier cabs.
if your cab is 85+ it is a no brainer to hydro it and very near the same for the earlier ones though you actually have to locate the correct spot to drill.
the 85+ cab has divots to mark the drilling locations I discovered when I converted mine.
I have a fairly complete parts listing from GM in my webshots album
hydro is the only way to fly,
reduced pedal effort and no more Z bar not reaching when twisted
mj is offline   Reply With Quote
Old 07-01-2002, 10:07 PM   #4 (permalink)
Member # 5821
How are your engine mounts??? Also check your tranny mounts.
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
Old 07-02-2002, 06:25 AM   #5 (permalink)
Member # 5146
mj, yeah I posted this on CK5 also. The firewall here at work won't let me look at one of your webshots pages, must be the one with swap stuff on it. I have decided to do the hydraulic swap, but I need as much info as I can get. like:What years to get parts from. Where to cut the hole in the fire wall.
To help with the advice, I have a 78' p/up 383, d60, 14b, 5.13s, detroit f&r, 44" boggers.
Any pointers or advice is greatly appreciated, because I need to do this swap SOON.
Old 07-02-2002, 06:29 AM   #6 (permalink)
Member # 5146
4banger, I am making a list of everything I need and where to get it, so thanks a lot!
rokcrln, Engine mounts are new poly, trans mounts are new also.
