th400: all the same? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-22-2008, 10:07 AM   #1 (permalink)
uda
Member # 34713
was wondering if all th400 are the same or did they come a bit beefier depending on what they came behind..... Example: Is a th400 behind a 4bt stronger than a th400 that came behind a 454? Or other applications?
Have one from a '81 chevy crew cab 4x4.Just want to know............
BASIC QUESTION................Are all th400 created equally?
uda is offline   Reply With Quote
Old 01-22-2008, 11:09 AM   #2 (permalink)
be cool, baby
tacoma73's Avatar
Member # 17896
"stronger"? No. 4bt, and 6.2 400's have different converters.
The 4bt should have a TH475, which you could argue is stronger, they have straight cut gears.... but the torque range on a 4bt isn't THAT impressive.
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly
tacoma73 is offline   Reply With Quote
Old 01-22-2008, 11:49 AM   #3 (permalink)
Member # 44659
Well, if yours is a 4x4 case, then you have the strong version of the case. Internals should be the bigger clutch packs and such since it was in a truck. I have seen some behind a 4.3 that had fewer clutches, but those are few and far between.
88K5 14b/d60 Self destruct mode switched to on! 97 Xcab Dodge crawler in the works. 77fj40/94fzj80
lumpdog is offline   Reply With Quote
Old 01-22-2008, 11:59 AM   #4 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
earlier (pre70) caddy th400s had the 6 clutch forward drum, and the 32 element sprag would slide right on it.
6 bolt pumps are different than 8 bolt pumps, one is narrower than the other *(the pump gear itself is narrower). the narrower pumps are more desirable for high rpm applications, because they dont pump TOO much fluid, which is a waste of hp at high rpm.
later cases required a snap ring in the case to keep things in order, too. Earlier cases didnt all need that snap ring.
as for heavy duty cases, I wouldnt worry about heavy duty and th400 being used in the same sentence.... theyre pretty heavy duty no matter what case you get.
You can upgrade to 4l80e planets to get some more strength, but they arent the straight cut like a 475 are. Unless youre towing 30k lbs, you wont need the straight cut gears.
edit: forgot the switch pitch stuff, too.
you can find 65-69 buick or olds th400s with a switch pitch converter that will allow you to have a stall that is induced by a switch.. kinda neat, but not meant for huge hp.
Theres probably a bunch of stuff i am missing....
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 01-22-2008, 04:14 PM   #5 (permalink)
be cool, baby
tacoma73's Avatar
Member # 17896
Forgot about the weird BOP stuff.
For anyone thinking that the TH475 stuff is a good idea for a rebuild or something, know that the parts alone are like $900... and you end up with a way overbuilt, noisier transmission for that.
I'm going to take this opportunity to remind everyone to keep their transmissions cool. Run a cooler!
Old 01-22-2008, 05:57 PM   #6 (permalink)
Devout Newbie Hater
Member # 20147
on the cooling note... caddy transmissions came with a 3/8 line fitting for the cooler lines.
Old 01-23-2008, 11:24 AM   #7 (permalink)
uda
Member # 34713
Thanks alot guys.I think I'm gonna keep the tranny and axles out of it and part the rest out.....
Anyone have an idea on what a 454 is worth? I believe it has a bit low compression in 2 cylinders.
Old 01-23-2008, 01:20 PM   #8 (permalink)
onetonbb74's Avatar
Member # 52039
There are 10 different output shafts for the th400.
[COLOR="Orange"]Wheeler:[/COLOR] 89 k5 350-700-241-60-14-5.38's-38 tsl...
onetonbb74 is offline   Reply With Quote
