Member # 92090
12 bolt rear-end diff question.
I have a 79 12 bolt rear diff with some sort of traction device in it (which doesn't work), I believe it's factory "gov-loc" limited slip. Haven't had the lid off in years, but I wonder if anyone knows If I can insert a MINI-SPOOL inside the Gov-Loc, or diff carrier at all?
Beaver Pleaser
Member # 13645
no. open carrier only.
1972 GMC Submarine 383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez Inclined to brute force attack a 70* incline with a Quadrajet 1997 GMC K3500 Suburban 454 / 4L80E / HP60 SAS / PROJECT TOWHOE |
Member # 47848
You could weld the spiders but I'd be careful. What sized tires are you running? Lot of HP? I wouldn't start dumping money into the 12 bolt. Search around and see what is available for upgrades within your budget.
[QUOTE]Yep, no sissy poser no use other than look good pansy crap on my truck! Jason Payne [/QUOTE] 1999 4Runner |
Member # 47848
Buying a red star will help in the searching and help the site.
Member # 92090
Thanks you guys. I am of the mind to not spend lotsa bucks into either the front nor rear axle. Right now my sits at around 4000 lbs & I plan on keeping it as light as possible. I have also switched to a very narrow rim to work with narrow tires. Currently running 34x9.5 ss.narrow super swampers. may go taller (35.5"x10.5").
Would you mind sharing any advice as to where to weld? Perhaps filling me into what tires you run & type of wheeling you've tried? |
skullfuckery
Member # 29016
weld the gears together, weld the gears to the carrier.
what gear ratios ? i have a fully welded 3.08 carrier, i think 3.54 3.42 also use this carrier, not 3.73
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#9 (permalink) | |
Member # 92090
That would be really cool. I'll give ya a PM. |
