4L80E Differences - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2008, 02:29 PM   #1 (permalink)
T_Spurger's Avatar
Member # 99760
4L80E Differences
What are the differences in the 4l80e transmissions through out the years? I am asking because i have a 91 4l80e and want to put it into a 96 chevy
Tim
1996 Chevy Ext. Cab Vortec 350/4l80e/np205 SAS Dana 60/14 bolt FF 37 x terrains
T_Spurger is offline   Reply With Quote
Old 02-06-2008, 04:30 PM   #2 (permalink)
Member # 76960
1993 New case connector and wiring harness (service package can update earlier models);
1994 New force motor, new electronics (no interchange or updates possible);
1997 Center lube transmission case (major design change, no interchange or updates possible);
1999 Planetary gear changes (retrofit possible if other parts are changed [on center lube case only]);
1999 New 2nd gear band (retrofit possible if other parts are changed); and
2003 New design overrun clutch (retrofit possible if other parts are changed).
Unimogger is offline   Reply With Quote
Old 02-06-2008, 04:32 PM   #3 (permalink)
bigbaggedbeast's Avatar
Member # 78847
i have a 93 in mine and i was told by my local tran's tech's that the 91 92's where the most problem related and to avoid them ... just a heads up if u care ...
if not ....
Originally Posted by Ashley21 View Post
You can take your maturity and morals elsewhere asshat
Originally Posted by The Joker View Post
Great and now you will need to patch the holes in your roof as a stupid tax, not to mention while you are "shooting to leak", they are shooting to kill.
bigbaggedbeast is offline   Reply With Quote
Old 02-06-2008, 05:08 PM   #4 (permalink)
Member # 16608
I think all 91's used the transfer case for the rear speed sensor...( instaed of the trans having 2, it has the input sensor but not the output sensor)...
I just went through this...on some 4x4 model 4l80e's they left the output speed sensor ring (toner ring) off of the output carrier assembly.
Make SURE you look in the speed sensor hole in the trans...and make SURE you see the toner ring.
Don't ask me why I know this...
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 02-06-2008, 05:14 PM   #5 (permalink)
T_Spurger's Avatar
Member # 99760
speed sensors
i am using a 2wd tranny with a spacer to a np205. it has the two vss on the drivers side
Tim
Old 02-06-2008, 05:33 PM   #6 (permalink)
Member # 41764
Actually the front one isn't VSS, it's a turbine input speed sensor. Just to clarify.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
JasonPayneMemorial
bggrnchvy is online now   Reply With Quote
