05 Chevy Equinox probs... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2008, 06:21 AM   #1 (permalink)
Member # 50695
OK, OK.. So I do not have a red star and I know that there has to be a thread or six about this so sorry but I can't search.
The wife has an 05 chevy equinox and the rear end sounds like trash. Buddy's wife had the same thing, told her it was "parking lot syndrom" and told her that they replaced the whole rear axle, under warranty I think. I Get some noise when making tight turns in a parking lot, but it is really loud if one of the rear wheels starts to slip. We just got a good amount of snow here the other day and it sounded really bad when I needed the AWD. Does this have some type of limited slip in the rear diff? Or is it some type of locker that is not disengaging? I found something online that was saying that the problem was in something I have never heard of and it looked similar to a transfer case. Any help or direction is appreciated on this.
g.schucks
g.schucks is offline   Reply With Quote
Old 02-15-2008, 09:02 AM   #2 (permalink)
GMCTruxrule's Avatar
Member # 51243
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 02-15-2008, 09:58 AM   #3 (permalink)
Member # 50695
Old 02-15-2008, 10:08 AM   #4 (permalink)
Member # 11975
Send a message via AIM to MikeW Send a message via MSN to MikeW Send a message via Yahoo to MikeW
Your engine is made in China
MikeW is offline   Reply With Quote
Old 02-15-2008, 10:26 AM   #5 (permalink)
Member # 89189
ive seen quite a few of those.its the rear axle
i think it starts out as a lube issue,that quickly turns into a bearing issue,
not long after that......when the bearing fails...the housing splits into about 3 pieces and you go nowhere!!!!!!!!!!
weve fixed some low mile units with synth fluid and ltd slip additive.....only a few...........prob 80% or better are bad bearings leading to the case failure.
how many miles you got on it?under 100k should be able to get help from gm.
been loyal to any chevy dealer??this may be a big decision factor.
did you buy it new?gm normally only helps orig. owners w/that stuff.
im in indiana,dont know how much more i could help...
...well,my .02
tallhoedude is offline   Reply With Quote
Old 02-15-2008, 10:27 AM   #6 (permalink)
let it eat's Avatar
Member # 83195
common problem, in the rear diff there is a viscous coupling for all wheel drive .i have replaced several for the same problem
big piles of parts that willnever be finished
let it eat is offline   Reply With Quote
