700r4 np203 combo questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-22-2008, 01:55 PM   #1 (permalink)
Member # 109176
i retired my 78 2500 full size after frame damage and stripped the drive train to build a new rig. i've since put together a 87 k5 blazer with my crate 350, dana 44 front and gm 14 bolt rear from the 78. it came with a 700r4 / np208 combo. i would like to run the 700r4 with the np203 from the 78. the 203 was hooked up to a turbo 350 with 27 splines on the output.
will this work??? can i change the output shaft on the 700r4 to match the turbo 350????
thanks for any help
SS Blazer is offline   Reply With Quote Quick reply to this message
Old 02-22-2008, 03:14 PM   #2 (permalink)
Member # 109176
to answer my question..... yes they will, both the turbo 350 and the 700r4 have the 27 spline output shaft
Old 02-22-2008, 06:03 PM   #3 (permalink)
Member # 99393
you just need extension piece between your trans and transfercase adapter/support part... i dont remember length of this part (between 3-4") but 208 is having longer adapter than 203 where is basically only an inch or so thick cast piece wich bolt to trans and where case is fitted.
dont blame me, i just born like this
Rytari is offline   Reply With Quote Quick reply to this message
