1 ton trans - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-25-2008, 07:48 PM   #1 (permalink)
Member # 43040
1 ton trans
I know, ive searched. I cant find what im looking for. I need to know if the 700r4 was available behind the 6.5 in 1998. I was told that's what is in the truck, but i hope its the early 4L80, because its free. (flame suit on)
Thanks in advance.
Josh.
95 S-10, one tons, 44's, 7lb pulley
Joshinator is offline   Reply With Quote Quick reply to this message
Old 02-25-2008, 08:47 PM   #2 (permalink)
mondtster's Avatar
Member # 25349
Send a message via AIM to mondtster
No 700r4 transmissions were used in 1998. They were dropped for the 4l60e in the early '90s. If it actually has a 700r4 in it then it has been swapped.
As for identifying the difference between a 4l60e and a 4l80e, search for pics of both and crawl under the truck and look. They have some pretty distinctive features that should help you identify which one it is.
mondtster is offline   Reply With Quote Quick reply to this message
Old 02-26-2008, 07:42 AM   #3 (permalink)
Member # 106059
Should be a 4l80e behind the 6.5. The 80 has a longer pan than the 60. The 60 pan will look basically like the 700. Remember that a diesel trans will have to have changes made to go behind a gas burner.
5540jd is offline   Reply With Quote Quick reply to this message
Old 02-26-2008, 08:39 AM   #4 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
60
80
700R4
actionpaintball is offline   Reply With Quote Quick reply to this message
