This is FALSE. Technically speaking, I don't believe any engineer "designed" an interference engine. When a timing chain or timing belt breaks while the engine is rotating, some valves may be stuck in their full open position while a piston comes to TDC. This is an unfortunate circumstance than can not be avoided in some instances but I would say it is probably not the case in a low compression TBI engine with a stock camshaft.
#7 (permalink) | |
Member # 28604
Teh sirch was kicking my ass, couldn't find a definitive answer. |
#9 (permalink) | |
Member # 28604
I had another thread going,
but cliffs notes: (how's this for keyword searches) 165,xxx TBI 350. Originally pulled timing cover, crank was at 12:00, cam about 10. Way out of time. I put it back to TDC(50/50 chance)? Test run, sputters pops, won't sustain. Distributor, no dice. Cam 180 out. Flip cam 180, 0 compression. Flip back, 0 compression. WTF? Test compression gauge, seems to work. Huh. Interferrence motor? Nope. Try other cam combos. Found it, motor's timed. Compression test, 30psi+/-1 across. Consistent but low. Issue? Drop in distributor, oil pump's out of time. Obviously. Long screwdriver? Donor Distributor/drill? Put together, keep running, get warm/ lubed, compression back? If not, fried rings, parkr? Yes, time ingition, done. Sound about right? Last edited by Rerock; 02-27-2008 at 08:31 PM. |
