Member # 52978
ls1 cooling problem
I have an ls1 in my yota with the radiator in the bed and the motor keeps over heating. At first i thought that it maybe a thermostat so i replaced it. Still had the same problem, so i replaced the surpentine belt because it was slipping. Still didn't work. I don't think that it is the water pump because when you remove the preasure cap on the radiator after it over heats the coolant is cold and is under preasure. I can't figure out what the problem is. Any suggestions?
[SIZE="7"]Rest in peace DAVE[/SIZE] |
Member # 106059
Are you sure about the water pump? Some of those engines had a reverse flow pump. Or if you are turning it backwards, it is just cavitating instead of moving water. Thermostat is in correctly isn't it?
1998 TJ, GM 350TBI, TH350, Dana 300, Dana 60's,5.38's,spooled, linked on 42's 1998 2500 4x4 Chevy, 454, 4L80E, 4.10s, tow rig 2002 Ford Excursion Limited 4X4 7.3L PSD, grocery getter/tow rig Last edited by 5540jd; 03-14-2008 at 10:31 AM. |
Member # 52978
Yeha the thermostat is in right because there is on;y one way to put it in because it is built into the housing. I don't think that the surpentine belt is on wrong because the tentioner pulley is level with the top of the water pump pulley so it seems logical to me that the belt run under the water pump and aver the tensioner pulley.
Member # 9991
I've had a couple LS1 motors.
Do you have 1 square inch of radiator per cubic inch? Is it an early model that could have the bad head gasket problem? I think the early 2000 and prior had this problem. I had a 2000 SS that would boil over sitting in the driveway after pounding on it. My 04 doesn't do it after beatin on it the same way.
[url]www.scotthansen.net[/url] |
Can you just take the thermostat out? I would try that first and then go from there.
Big Ed '78 Chevy Big-30 ![]() TTC 2010 here we come! Thanks to all who voted for us, we are gonna put on one hellufa show! Check out our online store. AMSOIL Your last stop for all your Automotive Synthetic Lubricant needs. Please PM me for quotes or questions. Link to places to wheel in Texas |
