chevy front end - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2008, 04:16 PM   #1 (permalink)
Member # 110934
chevy front end
hello everybody i have a front end that i pulled out of a 1975 chevy 3/4 ton i think i need to know if it is a dana 44, dana 60, gm 10 bolt or etc. it has 8 lugs and big lockouts thats all i know right now. i wrote some numbers down that was on it. On the long axle side the numbers are (603455 9) (5256be) then by the diff cover there are these numbers c36585 and 4-5cf. So if anyone can help it would be nice if you need more info let me know thanks goose007
goose007 is offline   Reply With Quote
Old 03-16-2008, 04:58 PM   #2 (permalink)
Member # 94248
dana 44...might want to post dumbass questions like this one in the newbie forum
craigbassett44 is offline   Reply With Quote
Old 03-16-2008, 05:09 PM   #3 (permalink)
Member # 75135
Chevy front end, Chevy forum, seems like the perfect place for a question like this. Just because you have a small penis, dont go gettin e-tough on everyone
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
N_Rod is offline   Reply With Quote
Old 03-16-2008, 05:19 PM   #4 (permalink)
Member # 94248
u know you get annoyed with dumb fuck questions like this in the wrong section of the forum. its the dumbest question ever
Old 03-16-2008, 05:52 PM   #5 (permalink)
bigyellowjimmy's Avatar
Member # 53682
Wrong. Its EASY to tell the difference with a little searching and if someone is too lazy to search for an extremely basic question then yes, they should be directed to the proper forum.
Freedom is only part of the story and half the truth….That is why I recommend that the Statue of Liberty on the East Coast be supplanted by a Statue of Responsibility on the West Coast.
Viktor E. Frankl
bigyellowjimmy is offline   Reply With Quote
Old 03-16-2008, 08:53 PM   #6 (permalink)
Banned
trkklr77's Avatar
Member # 29016
5cf is a dead give away, i just wish i could figure out what it meant. i copied down all of them off of all my buddies d44 and found no constant between them, other than that they are d44s.
and everybody above 31,490 are all useless post whore cock riders.
Old 03-16-2008, 09:15 PM   #7 (permalink)
Member # 13786
A 1975 3/4 ton is gonna be a Dana 44 (what some people call an HD) which has the locking hubs that 'bolt on' with the large 6 allen bolts. Gearing --most likely--will be 4.10. Axle tubes will be 2 3/4'' diameter, but will be close to 5/8'' thick. Spindles are one of a kind with the large inner 362a bearing and the hubs are notorius for spinning the inside race. It will also have the flat top knuckle on the right hand side that a lot of people want for doing their x-over steering
KWTMECH is offline   Reply With Quote
Old 03-16-2008, 09:18 PM   #8 (permalink)
Banned
trkklr77's Avatar
Member # 29016
spindles are not one of a kind, both of the ten bolt use the exact same spindle.
Old 03-16-2008, 09:22 PM   #9 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
more correct words are hardly ever spoken as truly.
as for the newbie being mindful of newbie style questions, there is a search button, if you want, I can post you a visual clue as to its appearance, its use is purely up to your initiative, and is directly proportionate to your ignorance of social requirements of this board. Simply put, "you dont have to like it, we dont have to care."
The original poster asked a question, which has been (graciously, i might add) answered with aplomb. N-rod, go take your soap box and shove it up your ass.
this thread should have been reported.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 03-16-2008, 09:23 PM   #10 (permalink)
Member # 61441
It will probably have the crappy 2 piece caliper mount plate, getting one from a later model 44 that is all the same thickness is a good upgrade.
The more you drive-The less intelligent you are.... -Repo Man Detailer
Tominator II is offline   Reply With Quote
Old 03-16-2008, 09:36 PM   #11 (permalink)
Banned
trkklr77's Avatar
Member # 29016
uhu why is one better that the other???
i prefer the full round for one reason. you can rest it on the ground and not your rotor. every body else likes the 1/3 rounds with the dust horse shit removed.
either way they are made from the same thickness steel.
Old 03-16-2008, 10:49 PM   #12 (permalink)
Member # 75135
You would have to step down off of it first
Old 03-17-2008, 04:57 PM   #13 (permalink)
GMCTruxrule's Avatar
Member # 51243
Don't pad your post count with senseless bs.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 03-17-2008, 05:28 PM   #14 (permalink)
be cool, baby
tacoma73's Avatar
Member # 17896
http://pirate4x4.com/forum/showthread.php?t=517960
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly
tacoma73 is offline   Reply With Quote
Old 03-19-2008, 04:04 PM   #15 (permalink)
Member # 110934
ok jackass this is my first time here so go fuck yourself and its not a dana 44 its a dana 60 unless a dana 60 cover will fit a dana 44 i am new to all this stuff so im sorry that you cant anwser a simple question but thanks anyways this goes to craigbassett44
Old 03-19-2008, 05:53 PM   #16 (permalink)
Banned
trkklr77's Avatar
Member # 29016
so how did you determine that its a d60?
because its 8 lug?
before 77 = no 60
3/4t = no 60
like i said before the 5cf is a d44 casting ###
the big hubs are often just extrenal hubs and most people think they = a 60.
Old 03-19-2008, 09:48 PM   #17 (permalink)
4xrick's Avatar
Member # 40518
because its 8 lug?
before 77 = no 60
3/4t = no 60
you took the words right outa my mouth. I am curious how you got that it is a 60, if it is someone swapped it in and there are very obvious things that a 60 has and a 44 does not, now lets see if you can name even one of them.
Yep I am that krazy k5 guy.
4xrick is offline   Reply With Quote
Old 03-19-2008, 11:42 PM   #18 (permalink)
Devout Newbie Hater
Member # 20147
4xrick, I think the OP is done. I dunno why...
if the guy cant figure out what axle hes looking at, he needs to stay in the newbie section
edit: to assist this guy, should he return, heres a photo... in the photo, on the lower right webbing of the housing, theres a number cast into it... 44 .... wonder how many years its gonna take before someone actually LOOKS there...
stole a pic off a jeepers site to help him ID a 60, though this is NOT a 60 front...
Old 03-20-2008, 07:25 AM   #19 (permalink)
Member # 343
Not to mention the kingpins on a 60......or lack of on a 44. Just a quick "glance" will tell you if it's a Gm60 or 44! No need to be wiping of grease and grime even.
EDIT: Another easy clue is the 44's U-bolt(s) and the 60's U-bolt and stud arrangement.
cj8scrambld is offline   Reply With Quote
Old 03-20-2008, 07:39 AM   #20 (permalink)
Member # 29210
Send a message via AIM to Davethorik
nothing really useful to add to this Charlie Foxtrot of a trainwreck of a thread, but I want to see the day where someone buys a Dodge D44 that has 3 u bolts and 2 studs because they think it is a 60.
:laughing:
Davethorik is offline   Reply With Quote
Old 03-20-2008, 08:06 AM   #21 (permalink)
Member # 343
GM 44 and GM 60. But your right.
Old 03-20-2008, 09:25 AM   #22 (permalink)
Member # 80727
Alright I havent exactly been picking for one but isnt the size difference between the two pretty damn obvious. I mean if I look at my 44 from 10 feet away, yes it has the same shape / build as a d60 but it is completely obvious that its smaller....
1994 Isuzu Trooper: OM617/W56/toybox
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is offline   Reply With Quote
Old 03-20-2008, 10:55 AM   #23 (permalink)
Member # 343
They are certainly obvious, but not everyone has a dimensional eye. The ones that have an eye can tell.....it is like many tasks with various types of work...you get an "eye" for measures....mechanics, carpenters, and etc.....you get the idea.
But for those that can't tell sizes from a distance.....walking through bone yards taking quick glances over and under trucks (sometimes buried and stacked on)....just look for the Kpins to be damn sure...we are talking GM44/60's here and I was "clarified" in the post above with my "key" elements between a D44 and 60.....clarified that some Dodge D44 have the 3 U-bolt and 2 stud setup as well.....BUT no Kpins!
They are similar with the quick look.....but the d60 has that little "edge"...the protrusion on the very bottom that the D44 does not have......
Old 03-20-2008, 06:17 PM   #24 (permalink)
Devout Newbie Hater
Member # 20147
that hairy lip, eh?
as a drivetrain fan, I have learned to ID an axle from 100 feet... given a silhouette or a bit of lighting. I cant believe people dont know their own
Old 03-20-2008, 07:15 PM   #25 (permalink)
Member # 100166
Well said. I can spot a Dana 60 in the front of a truck simply driving past, let alone sitting still. The 60 definitely hangs down a hell of a lot further, not to mention it has a very sharp diamond-shaped silhoette (compared to the more rounded silhouette of the 44). But, as noted above, I understand that not all have that eye (or is it a disease to be that obsessed with these trucks ?). Anyway, the "5-CF" alone gives it away as a 44...
Joe
K30_dump is offline   Reply With Quote
