Fuel System/ Ignition Problem On 350 TBI - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-13-2002, 09:25 PM   #1 (permalink)
Member # 2999
So i posted earlier about my 350 running hot. I think i have narrowed it down to either the fuel system or ignition as being the problem. The engine runs constantly hot and when i went to time it the timing mark was jumping up and down, The engine was put in in 97 new all the other components have 150000mi on them. Any idea what would go out around that milage. I replaced the fuel filter a few months ago. Any ideas? Thanks for the help,.
Dave
SLO LUNG is offline   Reply With Quote
Old 07-14-2002, 02:02 PM   #2 (permalink)
Member # 8938
I am wondering about the timing jumping around. ??? Did you have the little connector unplugged when you went to time it? This keeps the timing from moving around so you can set the static timing.
100% 1 Ton, Hit It
mnstr_fx is offline   Reply With Quote
Old 07-14-2002, 04:33 PM   #3 (permalink)
Member # 2999
Well when "I" Timed it it was actually my friend and i believe he had it hooked up correctly but maybe i'll try it again. Thanks,
Dave
Old 07-14-2002, 04:48 PM   #4 (permalink)
Member # 5021
timing too far advance
weak fuel pump
bad O2 sensor
sticking thermostat
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 07-14-2002, 09:12 PM   #5 (permalink)
Member # 2999
I have replaced the o2 sensor, and the thermostat the timing is jumping so i cant set it but i would not doubt the fuel pump thanks for the advice, Dave
Old 07-17-2002, 06:28 PM   #6 (permalink)
Member # 2999
ttt,
Still need help throw me a bone i'm going to college and need a ride.
Any help would be appreciated,
Dave Thanks
