Member # 52488
Looking to use a set of h2 wheels N tires on the 94 Z-71. It's half ton and I'm looking at putting in a D60 rear or a simi float 14 w/ a disk swap.
My question is on the front axles. Can the HUB assembly from a 3/4 ton bolt to the 1/2 ton spindles? and what would I need to do to the brakes if switching them also is in order? ![]() I'm not lifting it much at all, just using it for a driver and towing my Jeep. The goal is to be able to use the same wheel if needed from either vehicle and just to do something different. I haul and tow enough to trash a 10 bolt. If the fronts' going to be too complicated then I'll just use the D60 and get some wheel adaptors to 6-lug. Any ideas or recommendations to this swap would be good. Gear range will stay 3:73 or go to 4:10. (I've got a NEW Powerloc diff for a 30 spline D60, just sitting around waiting to be used)
87 YJ, 4:56s 1tons, 383/350, 205 T-case. "If you don't want it broke it, DON'T Let me drive it"!!! |
Member # 16536
It's been done, but it's a PITA. Not worth all the effort just to get 8 studs over 6. SAS it and be done....might not be the cheap way, but it's the stronger and cheaper in the long run way.
Oilfield Trash
Member # 64526
Not worth, I tried it. The lower control arms and lower balljoints are the same.
The upper control arms and upper ball joints are not. U can mount the 3/4 ton upper balljoint to your control arm but will need to drill a couple more holes. The eight lug knuckle is taller and requires more space at the frame than the halfton knuckle so u would need to move your mounts way up. The spline count in the unit bearin is the same, but u will need to remove the dust shield from the cv. U possibly could get the part #'s for the bearings in the unit bearing and have the eight lug hub pressed out and install it in your half-ton knuckle. I do remember reading a couple years back in one of the 4x mags were they were rebuilding the unit bearings, but can't remember which one. Or u could use the adapters, but if u plan on aftermarket wheels with less backspacng than stock, u will still have problems with the halfton unit bearings. If a straight axle is out of the ?, then seems like swapping the 8-lug hub into your knuckle would be the most dependable and easier. That is if the deminsions would allow it.
'91 k3500, 454, 4speed, 42" R-1's no lift '97 z-71, 3" BL, 38" tsl radial, 454/th400 '97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool, 34/10.50/16 ltb |
Oilfield Trash
Member # 64526
THat is a thought, but I am not sure that there is enough material on the hub flange. Also, u would need it redrilled every time u replaced with a new unit.
Member # 52488
Looks like I'm just gonna use the 60 rear and some 6lug wheel adaptors unless I can find the 6 lug simi-float 14.
I'd love to SAS the thing (I've got a D44 w/ 4:56s and a pass drop 208) but like I said, its just a daily driver and something to haul N tow my stuff with. Thanks for the input, not as easy as I was hoping it would be.
Mr Mom
Member # 94897
do you ever tow into soft stuff to where you really use the 4WD? You might want to consider a solid axle swap anyway. I am going to do it on my 2500HD just because I don't want to break out my tie rods while hauling out of sand or rough terrain. My vote is to dump the IFS. I know you said just a daily driver but I would think about the abuse.
89 jimmy D60/ff14bolt/400/203/205. Detroit rear, open front for now. |
#12 (permalink) |
Member # 98655
Not to be too different here but if you want 8 lug, get a rear sf 14 bolt and a front IFS setup from the front spindles to the upper control arm. I have seen 3/4 ton Suburbans with the same UCA as a 1/2 ton Suburban. Then you get the eight lug, bigger brakes and if you change your rear springs to 3/4 tons and front t-bars to 3/4 ton or 1 tons its doable. Lots of this shit is interchangeable but the Pirate guys are all about SAS so you are not gonna get an educated answer from here.
#13 (permalink) | |
Mr Mom
Member # 94897
