My shackle flip and 64 incher install - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-29-2008, 10:15 PM   #1 (permalink)
GMCTruxrule's Avatar
Member # 51243
As some of you might remember, I posted up a little while ago about some homebrew shackle flip brackets I made....here is the link to jog the ol' memory....http://www.pirate4x4.com/forum/showt...e+shackle+flip
Anyway, fast forward to today, and here are some pics of them installed.
I moved the front spring hanger forward 5.75 inches on each side to accomodate the 64"s (the old were 52"s)
I removed the rear 4 inch lift blocks, removed the bottom overload leaf from the 64" pack, and bolted them down with some new 5/8" u bolts.
I set my shackle angle to 30 degrees back, that is with the full weight of the truck resting on it. At full droop, the shackle is kicked forward 7 degrees.
And I bolted my shackle brackets down with some quality 1/2" grade 8 yellow beef.
Jacking up from the frame, I get a full 6 inches of suspension droop before the tires come off the ground.
Stay tuned, the 52" rear-to-front install is coming soon.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 06-29-2008, 10:20 PM   #2 (permalink)
Karnage
spidr's Avatar
Member # 55444
Looks sweet man, I got mine done up fr-rr and 64's and I love the way it rides. Flexes decent to.
spidr is offline   Reply With Quote
Old 06-30-2008, 05:31 AM   #3 (permalink)
Member # 76633
looks like it turned out nicely!!
cowboyup21 is offline   Reply With Quote
Old 06-30-2008, 11:41 PM   #4 (permalink)
Member # 51243
It turned out better than I expected, gotta mount some new shock brackets and fab up a new xmember for the shocks.
And then on to the fronts
Old 07-03-2008, 05:42 AM   #5 (permalink)
Who?????
Gutter Runner's Avatar
Member # 64846
Looks good. You should lump all your upgrades into a build thread of sorts.
My Chevy Build......Going Commando
Try my soup!
Originally Posted by caffiend View Post
"Damn you Gutter Runner and your meddling tasty potato soup."
Gutter Runner is offline   Reply With Quote
Old 07-17-2011, 08:12 PM   #6 (permalink)
Briman813's Avatar
Member # 161115
whats the necessary measurements the shackle reversal brackets. I am looking to make my own at the moment and it would make life so much easier if i had some measurements that are already in use.
Briman813 is offline   Reply With Quote
Old 07-18-2011, 04:05 AM   #7 (permalink)
Member # 173265
Hey GMC did you take any pics after the shocks were mounted, I am on to that part now!
Thanks
1981 K20 pirate4x4.com/forum/showthread.php?t=996844
chevy_phil is offline   Reply With Quote
Old 07-18-2011, 11:42 PM   #8 (permalink)
Member # 135105
I love the wood body lift.
prerunfun1 is offline   Reply With Quote
Old 07-19-2011, 10:35 AM   #9 (permalink)
Member # 51243
Yeah, about that....we do this gay inspection in Hawaii called "reconstructive inspection"...basically revenue enhancement for the state, they "give" you permission to own a modified vehicle as long as it passes their standards of reconstruction...and the wood blocks got me past their stupid inspection....
go figure.
Old 08-30-2011, 07:41 AM   #10 (permalink)
Member # 197458
Are the holes for the spring bushing bolts about the same place they would be on a stock spring hanger? Im trying to get some info so I can make some of my own. Yours look great, just need some good starting measurements!!
bpcole is offline   Reply With Quote
