Member # 89285
Rocker arm damage question with pics
So I'm tearing apart my 2000 RamJet 350 because of what I'm 95% sure is a blown head gasket and I find this:
The more heavily damaged one (the one on the right in the first pic) is from the intake of cylinder 1 and the other is the intake of cylinder 4. What could cause this? Valve lash seemed OK with a quick check before I pulled everything apart. Roller still spins freely, should I file down the burrs and run them or is this a definite replace item? Heads go in for testing tomorrow so I don't know if there are other issues yet. Thanks. |
Member # 51431
Looks like you didn't get the correct feeler guage when you set the lash on those puppies.
Or your springs are a bit weak for your application and allowing possibly too heavy valves to float. Hydraulic lifters? Might have a couple sticking on you. I gave up on self-aligning rocker arms after having these issues in the past with a set. I was chasing my tail with some of the above mentioned points to ponder, and of everything, an oil pump upgrade and better springs whooped it. Hows your valve stem tips looking?
[B]"Life is tough, but it's a lot tougher if your stupid." - John Wayne[/B] |
Member # 89285
It has hydraulic lifters. The engine is new to me. According to the prev owner it has never been opened up before and internals are stock. It's a crate motor with approx 15K miles but again this is according to the PO and I can't verify any of this for certain. Valve stem tips look good with no discernable damage.
Still wondering whether I can still run these rocker arms if everything checks out OK on the head. |
Bad Doctor
Member # 86878
Those dont look like the rockers that came with that engine.
Should be self-aligning stamped steel IIRC.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build /forum/chevy/994394-odins-me-too-short-crew-build.html |
Devout Newbie Hater
regardless of whether they are stock or not, the rockers are exhibiting damage that looks like they were not seated correctly when the valve lash was set initially. that would cause this type of damage, as would an over rev of the engine.
file em down, and try to rotate the washers enough to get a bit more guide from them. Be sure to clean clean clean clean. and make sure the roller tip on the rocker rolls freely after your modification. reset the lash, and when you restart it, watch them closely. either that, or buy a pair of rockers from the company... are those Crane rockers? they might sell just a pair if you ask them nicely.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
Bad Doctor
Member # 86878
In eighther case that engine requires guide plates or self-aligning rockers. IIRC.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build http://www.pirate4x4.com/forum/showthread.php?t=994394 |
#7 (permalink) | |
Either way...those are not stock Ramjet 350 rocker arms. I would check the lobe lift on the cam and the geometry of the rockers. There is a chance someone changed the cam out or put higher ratio rockers on without doing anything else and that could be a problem. Your valve lift should be .431/.451. If you're closer to about .461/.480 you might want to look at the other components of your valvetrain as this would indicate 1.6 ratio rockers.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE] [QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit. [/QUOTE] |
Member # 89285
Thanks for all the replies.
I'm going to go ahead and replace the rockers. Here's a pic of the rocker itself: It is a 1.6 ratio rocker. I spoke with Scott @ Gilbert Chevrolet and sent him the pics. He says that these are the stock Ramjet 350 rockers and are actually made by Crane. I ordered two of them and he was nice enough to break up a complete set to get me them quicker while he orders the individuals to replace his stock. He did say Crane might have a rebuild kit but in the interest of getting everything back together I just went ahead and got new ones. |
Member # 98655
Make sure you prime the engine good before you restart it. Are you gonna dead set the hydraulic lifters? Just make sure your lifters are pumped up before you fire again, because as Grumpy said, this looks like it could have happened at inital startup. Good idea for any engine with hydraulics that has sat a while. Pull the plugs and crank it over till you get oil pressure. Then install plugs and fire it.
#10 (permalink) | |
Member # 89285
