are all these interchangeable? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-14-2008, 07:32 PM   #1 (permalink)
Member # 95243
Send a message via AIM to redneckchevyman
For a stock late 70s chev half ton, if i decide to install th400, np205, 14bolt front and rear, will these all bolt right up in place of the stock parts or will I need to do some fab work or purchase anything else. Thanks.
redneckchevyman is offline   Reply With Quote
Old 07-14-2008, 07:48 PM   #2 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
oy.
no GM half ton 4x4 ever had a th400 as a stock transmission with an NP205 behind it.
front driveshafts will be within a foot, but probably wont fit 100% if you use the one ton stuff, as they may be a tad short in the front, and just wrong in the back.
everything else will bolt up.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 07-14-2008, 08:08 PM   #3 (permalink)
silver98Z71's Avatar
Member # 76470
Except the 14bolt front.
-Daniel
1998 K1500 5.7/4L60e/np241/Corp 8.5/Corp 9.5/35" MTZs
1994 S10 Blazer 4.3/4L60e/np233/D44/AMC 20/37" Boggers
1985 S10 1.9/T4/Corp 7.5/255s
silver98Z71 is offline   Reply With Quote
Old 07-14-2008, 08:12 PM   #4 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
also depending on what you get the 14 bolt out of you may have to move the spring perches and the shock mounts. also going to need new ubolts.
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 07-14-2008, 08:13 PM   #5 (permalink)
Devout Newbie Hater
Member # 20147
D'OH!
forgot about that one... but I know SOMEONE built one.
Old 07-14-2008, 08:15 PM   #6 (permalink)
Member # 76470
D'OH!
Yes sir. There is a guy down the highway from my house who has a 14bolt center with D60 outters under his '96 K3500.
-Daniel
Old 07-14-2008, 10:11 PM   #7 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i have one too, built by lincoln machine.
wfo used to sell them rtr.
if you you got everthing from one truck then yes it will all bolt together.
if the shafts came from xx , the tcase and tranny came from xx, and the axles from xx, then you will just need to get the shafts modded.
the only obvious hang up is the 14bff from a 3/4t or a 1t? 1t will need the springs perches moved.
Old 07-15-2008, 01:39 PM   #8 (permalink)
Member # 76470
And I think some of the 3/4ton trucks had both of the shocks mounted towards the rear. But that is trivial.
-Daniel
Old 07-21-2008, 05:37 PM   #9 (permalink)
Member # 95243
Doesnt sound too difficult to do. Im just tired of frying trannys, prolly because im running 3.73gears with 37s haha. I was told to just rebuild, get a cooler and run 4.11 gears and I wont have to worry bout another tranny for a while. One last thing, I know the 205t case was build better mainly because its gear driven and not chain, correct? Should I just stick with th350 and 203 or spend the time and money and fab up what I was talking about above?
Old 07-21-2008, 05:41 PM   #10 (permalink)
Member # 112785
if you are staying with the turbo 350/203 i would say to change gears to either 4.56 or 4.88 your truck will thank you for it
old ugly 54 chevy is offline   Reply With Quote
Old 07-23-2008, 07:34 PM   #11 (permalink)
Member # 95243
Im sure it would. Thanks for the info guys.
