2wd Chevy 3/4 ton to 4x4 with 1 ton axles - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-11-2009, 03:40 PM   #101 (permalink)
78stepsideUAK10's Avatar
Member # 92930
Got the transfer case in with no cutting
I can't shift it though, so I'll have to cut one for that
And this is a first for Florida, I only have a front driver shaft , most trucks down here haven't had one in years
My floor also turned out to be in very good condition
The wheels will be bronze. I took a pic of a wheel that I sprayed a small section but you cant really see it that good.
78stepsideUAK10 is offline   Reply With Quote
Old 04-11-2009, 03:51 PM   #102 (permalink)
Member # 92930
For bead locks I don't think You can beat this price
40 per wheel
http://www.speedwaymotors.com/Bead-L...Wheel,170.html
Old 04-11-2009, 04:43 PM   #103 (permalink)
Karnage
spidr's Avatar
Member # 55444
Are those like 12 ga stamped sprint car beadlocks? I wouldn't run them on anything 4x4 personally, especially when you can get them for around $50 per wheel on the board here.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is online now   Reply With Quote
Old 04-11-2009, 04:53 PM   #104 (permalink)
Member # 92930
Yeah something like that, I was just thinking those would balance better than heavy 1/4" steel
I'm looking into rim stiffeners also, I have reverse centers so I wouldn't benefit too much with bead locks. I think they are probably my best bet
Old 04-11-2009, 04:57 PM   #105 (permalink)
Karnage
spidr's Avatar
Member # 55444
On a big Interco bias balance is not going to happen well regardless of the beadlock. A 1/4 thick lock will likely balance just as well really though since it's a balanced pattern all the way around. It's the tire that doesn't balance. If it bothers you, fill it with airsoft or golf balls and call them good.
Krush RT IFS/IRS
Old 04-13-2009, 06:01 PM   #106 (permalink)
Member # 92930
I ordered a hydro cylinder today
1.5"x8 with a 1" rod, pretty beefy
http://cgi.ebay.com/NEW-HYDRAULIC-CY...ayphotohosting
Web wheeler
Old 04-13-2009, 08:05 PM   #107 (permalink)
Hold Fast
Elvis38's Avatar
Member # 101407
[QUOTE=78stepsideUAK10;9685053]For bead locks I don't think You can beat this price
40 per wheel
http://www.speedwaymotors.com/Bead-L...Wheel,170.html[/QUOTE
I wouldn't run those. Circle track guys around here fuck'em up all the time, even on the shit boxes and Modifieds. Lightwieght- yes, Strong and what you need -no.
Elvis38 is offline   Reply With Quote
Old 04-14-2009, 10:06 AM   #108 (permalink)
Member # 92930
Yeah I'm just gonna get rim stiffners
Specifically these
Web wheeler
Old 04-14-2009, 02:25 PM   #109 (permalink)
Member # 92930
I'm the proud new owner of a harbor freight pipe bender
I'll do the back tube half with poo pipe
Web wheeler
Old 04-14-2009, 05:51 PM   #110 (permalink)
Hold Fast
Elvis38's Avatar
Member # 101407
Specifically these
Don't those go on the bead that your supposed to weld the beadlock too. Or do those sit inside and leave room for the beadlock? I'm thinkin either non beadlock wheels or H-1 style wheels.
Old 04-14-2009, 05:59 PM   #111 (permalink)
Member # 92930
Non bead locks
Web wheeler
Old 04-15-2009, 05:17 PM   #112 (permalink)
Member # 92930
Web wheeler
Old 04-26-2009, 04:10 PM   #113 (permalink)
Member # 92930
Poop pipe
Web wheeler
Old 04-26-2009, 04:13 PM   #114 (permalink)
Member # 92930
The rear is going to go up a little bit and the front will be lowered some
I'm not sure what I want to do to the front bumper yet either, either a stinger and the two supports or something pre runnerish like this
Heres the stinger
Web wheeler
Old 04-27-2009, 12:45 PM   #115 (permalink)
Member # 92930
Bought these lowering shackles on ebay
Can't go wrong for 45 bucks, the bushings alone will cost me like 20 bucks
I'll probably box them
Web wheeler
Old 04-28-2009, 06:03 AM   #116 (permalink)
Member # 19615
Send a message via AIM to afroman006
I have been running the janky looking Beltech "lowering" shackles in the "flipped" orientation on my trail rig for the last 4 years and have had no problems at all with them. They seem thin and cheap at a glance but hey, they've held up just fine and I havent done any extra bracing on em.
Texas A&M Offroad
84 Chevy -Pigpen- Best trail truck there ever was...
afroman006 is offline   Reply With Quote
Old 04-30-2009, 01:00 PM   #117 (permalink)
Member # 92930
Got them today
A little thicker than 1/8"
Around 6.25" eye to eye
Web wheeler
Old 05-01-2009, 07:11 AM   #118 (permalink)
Member # 134546
great build! that is up there on my list of projects (its a long list tho) i already have the '86 2wd 1/2 ton burban 350/TH350 and nice body, and a 2wd '86 3/4 ton burban 454/TH400 thats rusty as hell but has a big motor......all i need is my 4x4 parts, time, money, and knowledge!
once again great build dude!
RedZeppelinXJ is offline   Reply With Quote
Old 05-02-2009, 07:46 PM   #119 (permalink)
Member # 19615
I know you're well past this point but hacking the floor to move the t-case up would probably be worth the effort. I clocked the shit out of my case but quite a bit of clearance can be gained with an unclocked case too. My truck was previously a 2wd too.
Texas A&M Offroad
Old 06-24-2009, 11:28 AM   #120 (permalink)
Member # 92930
I think I'm going to go to an np241 and I'll need to clock it up so rocks cant get to it.
I've got some more crap done though, not much though, I've been lazy. Mostly stuff you can't see, like transmission cooler, wiring, alternator, power steering, brakelines
Here is the ride height after the shackles, the angle is perfect now
I think I'm gonna try to pull a leaf out to lower the front
EDIT: I need to get more bronze paint also
Web wheeler
Old 06-24-2009, 01:05 PM   #121 (permalink)
Member # 106274
looks good so far
subscribed
Black06 is offline   Reply With Quote
Old 07-07-2009, 10:43 PM   #122 (permalink)
Member # 92930
I made the rear d shaft and mounted rear shocks, my front shock towers will be here probably tomorrow.
Web wheeler
Old 07-08-2009, 03:20 PM   #123 (permalink)
Member # 92930
Front shock on, I'll do the other side tomorrow.
Then I'll make my square dshaft
Web wheeler
Old 07-09-2009, 01:23 PM   #124 (permalink)
Member # 136619
Where did you get the brake for the 205?
whiskeydented is offline   Reply With Quote
Old 07-09-2009, 01:51 PM   #125 (permalink)
Member # 128238
Man I like it.
LegendKiller89 is offline   Reply With Quote
