SAS Brakeline question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-23-2008, 05:45 PM   #1 (permalink)
Member # 115642
Those who are doing, or have done a SAS on 88-98 chevy,
which extended brake lines for the front did you use?
I'm using a Dana 44 hp with dual piston calipers from a 79 f250.
Thanks for any info!
Chevywhite is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 06:30 PM   #2 (permalink)
Member # 343
Not completely sure what you're asking.
But most likely the ones that have sufficient length for your amount of lift.
The obvious part is they have to fit the fittings on the caliper and the hardline on the opposing end.
cj8scrambld is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 06:52 PM   #3 (permalink)
Member # 115642
That's what Im asking.
What braklines will go from my Chevy hard lines to the ford dual piston caliper? The caliper appears to have the same type of fitting as my chevy caliper but I'm not sure, I just wanted to know what someone else used?
Thanks
Old 07-23-2008, 07:21 PM   #4 (permalink)
Member # 74068
All aftermarket parts. Mostly Earl's fittings and lines. I've got a 3/6" double flare to-3AN fitting at the frame, then I used a -3AN to Banjo at the caliper. Braided stainless lines in between. I don't recall the size/pitch of the banjo bolt right off hand though.
Check Summit or Speedway Motors.
[b]Tow Rig -[/b] 2004.5 Dodge 2500 CTD
[b]Trail Rig -[/b] 1991 Chevy K1500 - D60/14FF
:skull:
JohnnyU is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 07:54 PM   #5 (permalink)
Joey D's Avatar
Member # 20053
I bought mine from Offroad Unlimited, just measure for the correct length.
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears
06 D Max Express
Joey D is offline   Reply With Quote Quick reply to this message
Old 07-23-2008, 08:17 PM   #6 (permalink)
Member # 41764
I pieced my lines together with braided lines and adapters to 3/16" IF at the hardline and 7/16" banjos IIRC at the calipers (Chevy 60) all from AFCOracing.com
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
Old 07-24-2008, 02:10 PM   #7 (permalink)
Member # 68512
i am running superlift part # 89365. the are originally for a 9" lift on a full size. i lucked out and got them as a scratch and dent item on ebay and paid $26 shipped for them. i found them here for $105 and change. they work well for me, i've got about 12" of lift. my calipers are different, but they should be similar.
http://www.ultimateautoaccessories.c...PROD/LKS/89365
you can see it here, its zip tied to my shock.
89 s10, flogged regularly
94 burb, tow rig
Donahue is offline   Reply With Quote Quick reply to this message
