Dana 70 front ?'s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-29-2008, 10:06 PM   #1 (permalink)
Member # 116433
Send a message via AIM to Bad75GMC
Dana 70 front ?'s
I can get a Dana 70 front axle with 4:88 gears for $750. Is this a pretty good price? Is this a good axle? I got a GM 3/4 ton 10 bolt to go under my 75' GMC right now but been lookin at D60's and they go for $1000+ and say this D70 and thought this would be a better way to go then the 10 bolt and cheaper then the D60. Is there cross-over for this axle or would I need to modify to get Cross-over?
thanks yall
1975 GMC Serria K-15
1994 Jeep Cherokee 4dr 4x4
Bad75GMC is offline   Reply With Quote Quick reply to this message
Old 07-29-2008, 10:21 PM   #2 (permalink)
trkklr77's Avatar
Member # 29016
its all based on d60 stuff just bigger.
have you seen this axle yet?
is it closed or open knuckle?
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 07-29-2008, 10:25 PM   #3 (permalink)
Member # 116433
no I haven't seen picture's yet, hopefully he'll post some tommrow.
Would it matter open or closed knuckle?
Old 07-29-2008, 10:32 PM   #4 (permalink)
trkklr77's Avatar
Member # 29016
yup, i would drink my own piss before using a closed knuckle.
Old 07-29-2008, 10:33 PM   #5 (permalink)
Member # 116433
why's that?
Old 07-29-2008, 10:43 PM   #6 (permalink)
trkklr77's Avatar
Member # 29016
drum brakes
kuckle seals leak horibly[espeicaly bad for florida swamp goobers]
goofy axle joints
on top of just all around hard to get parts for.
Old 07-29-2008, 10:45 PM   #7 (permalink)
Member # 116433
No way of upgrading to disc? I know I can do a disc brake swap on my 14 bolt FF rear for only $320.
Probley to upgrade for seals im sure.
Old 07-29-2008, 10:59 PM   #8 (permalink)
77k5's Avatar
Member # 35786
Closed knuckle front D70's use small joints, small shafts, parts are expensive, etc.
Open knuckle front D70's are ridiculously rare and even then only parts of them are marginally stronger than a D60.
If its closed knuckle its not even worth half of $750.
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
970-945-7777
77k5 is offline   Reply With Quote Quick reply to this message
Old 07-29-2008, 11:34 PM   #9 (permalink)
trkklr77's Avatar
Member # 29016
sure you can. but why spend the money, now you are over what you would have spent on a d60 open. hell there are 2 open d70s on the board for sale now, im sure you could get them shipped for less than what you would piss away dicking witha closed knuckle.
Old 07-30-2008, 07:14 AM   #10 (permalink)
Member # 15404
Closed D70 = 1/2 ton shafts and joints.... it's not worth your time and you can't convert it over to anything strong without putting open d60 inner C's etc on it so you might as well pick up a open d60/70 to start with.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 07:57 AM   #11 (permalink)
SIRJR's Avatar
Member # 46338
I have an opened D70 fron for the rear steer on my buggy. PO put it in and it is one stout setup. Now I have broken the outer shaft on it and have had a difficult time finding a replacement. Looks like it is going to end up being an D60 outer afterall.
77 Bronco with a little attitude & 76 Bronco Buggy with a lot of attitude!
SIRJR is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 08:18 AM   #12 (permalink)
Member # 25397
Dana 70 outers are the same thing as 35 spline Dana 60 outers. So why can you not find the shafts?
Dik
JV post #87
Tellico Post #385
sandawgk5 is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 08:28 AM   #13 (permalink)
trkklr77's Avatar
Member # 29016
not shit i have 3 of them sitting on my floor. and those are stock, not to mention all the after market spanky ones available.
Old 07-30-2008, 09:00 AM   #14 (permalink)
florida4x4's Avatar
Member # 13645
get pics!
1972 GMC Submarine
383 /
/ TH350 / Dubblah / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez / forsaken
1997 GMC K3500 Suburban
TC76 L33 / 4L80E / HP60 SAS / PROJECT TOWHOE
Foot On, Foot Off. There is no in between.
florida4x4 is online now   Reply With Quote Quick reply to this message
Old 07-30-2008, 09:02 AM   #15 (permalink)
trkklr77's Avatar
Member # 29016
yes, this all moot if it turns out to be a open knuckle.
Old 07-30-2008, 01:31 PM   #16 (permalink)
Member # 116433
its closed knuckle with durm's
Old 07-30-2008, 02:02 PM   #17 (permalink)
trkklr77's Avatar
Member # 29016
Pass!!!!!
Old 07-30-2008, 02:13 PM   #18 (permalink)
florida4x4's Avatar
Member # 13645
A local guy tried to sell one of those for $100 and no got no takers.
1972 GMC Submarine
383 /
Old 07-30-2008, 02:18 PM   #19 (permalink)
Member # 116433
alrighty thanks yall
Old 07-30-2008, 03:40 PM   #20 (permalink)
Banned
Member # 91791
Send a message via AIM to g-wizz
nothing in them is small. not the shafts. they dont use u joints they use a tracta joint. its a four piece joint that is really really wierd looking. no bearings what so ever just big pieces of metal rubbing against one another.
got mine at a junkyard for 200. im going to retube it to chevy specs and put 60 outers on it.
if its closed knuckle dont even bother with that shit. if it were cheap enough i would say retube it. but for your case i wouldnt mess with it. you would be better of just getting a rear dana 70 or 80 and starting with that.
g-wizz is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 07:10 PM   #21 (permalink)
big mudder's Avatar
Member # 24075
Not to mention the tierod that is mounted behind the axle and hangs down lower than the housing.They are worth about ten cents a pound (unless scrap price has went up)
big mudder is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 09:41 PM   #22 (permalink)
Member # 68512
only the new d70's from the kodiac's have the tie rod like you mentioned. all the old ones that are mentioned in this thread are the typical configuration.
89 s10, flogged regularly
94 burb, tow rig
Donahue is offline   Reply With Quote Quick reply to this message
Old 07-30-2008, 10:15 PM   #23 (permalink)
Member # 29210
Send a message via AIM to Davethorik
taken from mr.n's page:
the old dodges, and im pretty sure internationals too, had the tie rod in the back.
i wouldnt scrap any D70 front before checking if it had a two piece case (nice) or a power lock or detroit (even better)
Davethorik is offline   Reply With Quote Quick reply to this message
Old 07-31-2008, 08:17 AM   #24 (permalink)
big mudder's Avatar
Member # 24075
Ive seen a few and had a few and all of them have had the tierod in the back.Im sure theres variations but all the closed knuckles/drum brakes 70's I've saw were that way.
Old 07-31-2008, 01:15 PM   #25 (permalink)
Grumpy_old_fart's Avatar
Member # 20147
why couldnt you just install some deadenbear/Crane C's on em
Empathy, apathy, sympathy.
Sympathy is between shit and syphilis in the dictionary.
Grumpy_old_fart is offline   Reply With Quote Quick reply to this message
