305 to 350?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-26-2008, 05:00 PM   #1 (permalink)
xjjeep4x4's Avatar
Member # 72440
305 to 350??
this i think is a dumb neeebe question.... but here we go.. i picked up a sb with casting numbers 14010202 says its 80-84 305. what is the big difference between the 305 (crap) to the 350? i got the engine for free thinking i was going to bild a nice sb, i guss thats out the window any help would be nice thanks
R.I.P. DOZER
xjjeep4x4 is offline   Reply With Quote
Old 08-26-2008, 05:05 PM   #2 (permalink)
Snowbird13's Avatar
Member # 44136
45 ci seach
Hammers Thread post #1388
Tellico Rallypost # 285
Snowbird13 is offline   Reply With Quote
Old 08-26-2008, 05:06 PM   #3 (permalink)
xjjeep4x4's Avatar
Member # 72440
so could i just bore it?
R.I.P. DOZER
Old 08-26-2008, 06:18 PM   #4 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
sure...
bore it.
lets see....
3.735 bore for a 305
4.000 bore for a 350
0.265 overbore for the 305 might be a tad much though... I think the cylinder walls are only about .180-.220 thick at best...
maybe you can sleeve it and make it work, but I think it might be smarter just to get the 350 block.
of course, you could make a 331 out of the 305 by using a 3.75 stroke crank.... kinda like beating a dead horse, but cubic inches are cubic inches.... right?
lol... thats funny shit, right there...
305s and 350s share the same 3.48 stroke and deck height... and head bolt pattern...and a myriad of other things. 305s sometimes come with a smaller chamber on the cylinder head, which equates to smaller intake valves, like a 1.84 vs a 1.94 intake valve... .1" intake valve size is noticeable. it gets you from wheezy to breathing.
so, you can use the stock 305 heads and get more compression, but lose breathing ability... would you choke the engine down and then demand it to breathe better by giving it more cylinder? some people say its a good idea. I dont.
if its going in a toyota, leave it alone. if you want mileage, leave it alone. if you want to drive it on the street and make sure your rig doesnt have the power to pull a sick whore off a piss pot so your kid cant beat it up too much, leave it alone.
just my opinion, its worth what you paid for it....
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 08-26-2008, 08:47 PM   #5 (permalink)
xjjeep4x4's Avatar
Member # 72440
Originally Posted by Grumpy_old_fart View Post
sure...
bore it.
lets see....
well put, thanks
i was just thinking for a min that maybe i could use it.... is if even possible to run 305 heads on a 350? i know the valves are smaller ao i guss not?
R.I.P. DOZER
Old 08-27-2008, 11:50 AM   #6 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
It's possible and would give you more compression, but those itty bitty valves aren't going to help you. You could just as easily run Vortec heads on the 350 which have a 64cc chamber likely giving you better compression AND better flow for the same price as just about any junkyard head (in my searching anyway).
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote
Old 08-27-2008, 05:15 PM   #7 (permalink)
Member # 67828
Send a message via AIM to Nskeeter99
IF you wont to get going then just use it. you could build it up some. if you got the vortec heads like prvesuly suggested, and an intake would add some power. It also could be transfer to a 350 at a latter date.
Nskeeter99 is offline   Reply With Quote
Old 08-27-2008, 07:12 PM   #8 (permalink)
xjjeep4x4's Avatar
Member # 72440
i ran the casting numbers on the heads 14014416.... this is what i found
14014416 305 HO, 80-85, 58cc, 1.84-1.5, 165/59cc ports, 7 bolt ex.
so the "ho" meaning high output heads??
why im thinking about try'n to run 305 heads on a 350.... because i have free valves, seal, seats, guids, ect..
R.I.P. DOZER
Old 08-27-2008, 07:40 PM   #9 (permalink)
Devout Newbie Hater
Member # 20147
ya must not have read my post.... or just tried to studiously ignore it.
Old 08-27-2008, 08:24 PM   #10 (permalink)
xjjeep4x4's Avatar
Member # 72440
i read it and see what you saying. my deal is my 350 heads are done for.. they leak like a mother, i was just thinking ive got the heads & new valves, seats and all the goodies to go with it for free! yes being a cheap mother fucker that i am.... maybe it will work? maybe it will suck so bad ill have to save up for a engine. it might have to work just to keep the old tree-fifty go'n!
thanks grumpy
R.I.P. DOZER
Old 04-29-2012, 10:12 AM   #11 (permalink)
DrillANWR's Avatar
Member # 185422
Here's to resurrecting old threads
So I thought this was retarded at first. But I think I might be retarded.
Are you saying the heads are interchangable between a 305 and a 350? How similiar are the blocks?
If you voted for Obama in 2008 to prove that you're not a RACIST... vote for someone else in 2012 to prove that you're not an IDIOT!
DrillANWR is offline   Reply With Quote
Old 04-29-2012, 10:20 AM   #12 (permalink)
El Jefe's Avatar
Member # 14072
Other than cylinder bore, on these years they're identical.
Thus far you have been adrift in the sheltered harbor of my patience.
El Jefe is offline   Reply With Quote
Old 05-03-2012, 11:40 AM   #13 (permalink)
Member # 192110
find a 70's or 80's farm truck with low miles. around here there $500 to $1000 disassemble new rings seals oil pump. reassemble, done! Why go thru all the work for a 305 just find a 350 they were the most mass produced v8 on the planet AKA cheap as fawkin dirt.
Why waist your time with tinkering with a 305? Do you not have craigslist? I just found a 350 rebuilt bored .30 over guy needs it gone yesterday $500obo yeah its in iowa but i am sure the same thing will pop up within a month on your local CL.....
1992 chevy 1500 350tbi, HPdana60 open, Sterling 10.5 truetrac. Fishin/winter truck
92solidaxlechevy is offline   Reply With Quote
Old 05-03-2012, 06:37 PM   #14 (permalink)
Member # 172772
Save up for a LS GM motor, like a 5.3 or 6.0, they can be found for cheap, and they make nice power with lil amounts of money, I found my LS 5.3 for 400 bucks of craigslist and it was in the truck so I could here it run, only has 116k miles on it, I'm swapping it into my 93 Chevy once my 241k mile 350 hits 250k or starts slowing down...
93 K1500: Project
94 K1500: Tow Rig/DD
Level_B is offline   Reply With Quote
Old 05-04-2012, 05:30 AM   #15 (permalink)
Member # 198851
416 305 heads on a 350 is a cheap way to boost compression ratio.On a mild engine the smaller ports and higher compression will give more midrange power.416 heads are a lightweight casting and must be checked for cracks.
ADChevy4x4 is offline   Reply With Quote
Old 05-04-2012, 07:06 AM   #16 (permalink)
Member # 9991
If you already have the heads, and can't afford another set of 350 heads then bolt them on. They will work, but most intelligent people know that the increase in compression does not offset for lack of flow.
If I were young, and had other priorities then I would use them and put the savings to better use.
[url]www.scotthansen.net[/url]
MrWillys is offline   Reply With Quote
Old 05-04-2012, 11:19 AM   #17 (permalink)
Devout Newbie Hater
Member # 20147
you arent seriously asking this question, are you?
Old 05-04-2012, 12:30 PM   #18 (permalink)
Member # 123514
Send a message via AIM to frikenwoodro Send a message via Yahoo to frikenwoodro
He may not be but I am
Or am I?!?!?!?!?!
I don't build it pretty I build it to function.
frikenwoodro is offline   Reply With Quote
Old 05-05-2012, 07:30 AM   #19 (permalink)
Devout Newbie Hater
Member # 20147
Or am I?!?!?!?!?!
you?
yer bein a tard...
