Member # 76609
Location: Pilot Hill, CA now Woodland, CA; 1 hour further from the con :(
6.0 starting problems
I got an 02 silverado 2500hd with the 6.0 and am having some starting issues. The motor will turn over and not start the first or second try and then start VERY weakly on the second or third try, usually the third try. It is my wifes truck and as far as I know she has kept up on the fuel filter and such. Should I be able to here the fuel pump turn on when the key is turned on? I know I can on my older 350, but wasn't sure with the newer trucks if they made them quieter. thanks
YJ on custom frame 350 sm465 twin stick Dana 300, 35 Spline 60's f/r, arbs f/r, hydro, on 42" IROKS |
#2 (permalink) | |
Vortec Scout II
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
Member # 76609
thanks will double check on the filter and listen better for the pump.
Member # 73413
chevy's have a problem with the fuel pump check valve. The system is designed to hold pressure in the line when it is shut off. So when you start the vehicle there will be pressure in the lines already, and therefore start quickly. The check valves go bad all the time, therefore the lines will be empty, or close to empty. So when you go to start the truck you have to fill the fuel lines up to the fuel rail before it will even try to start. Giving you the extended crank. Unfortunately the check valve is not serviced separately and you must purchase the whole fuel pump module to correct the problem. One way to diagnose this is to turn the key from off to on a few times before attempting to crank the engine. This will prime the system, filling the empty fuel lines. Then if it fires right off, you know that is the issue. Of course you can also connect a fuel pressure gauge to the vehicle, and let it sit for a while and see if it maintains pressure. I have seen quite a few that drop off almost immediately.
Member # 76609
yep that sounds like my problem, I had to drive the truck today, and I tried turning the key on and off a few times before starting it and it would fire up when I gave it the first full turn of the key, so to fix this I need to replace the fuel filter, and that will fix the check valve problem.
