Member # 97240
75 GM 14B - Help needed!
Hey Guys,
I recently got a GM 14B out of a 1975 Chevy 3/4ton truck. Front axle is a Dana 44, both axles are 8 lug. So this is 10.5 ring gear. I'm looking into getting a spool for it, and a different Ring and Pinion ratio, and This whole "Thick Cut" Thing is confusing me. I'm a Samurai Guy, so I have no experiences with these axles. All I want is a spool and 5.38 Ring and Pinions. Do I need Thick Cut gears? Can I use the Carrier I presently have? (I'm planning on using a Mini spool, unless you guys advise me to use a full spool - But with only 70HP, I should be fine with either, I assume) Hope you can help me out, Thanks guys! - Isaiah |
Member # 86524
Check out the 14 bolt bible in the tech section, has answers to all the questions you could have.
But since im bored and trying to kill time anyway, i will answer the question . There are 2 carriers on the 14 bolt, 4.10 and numerically lower, and 4.56 and numerically higher. If you want to run numerically higher gears where you had 4.10s before, you need to buy the thick gears. If you have 4.56s+ already, then you get the standard gears.EDIT: dont even bother with the mini spool, just weld it up!
[URL="http://pirate4x4.com/forum/showthread.php?t=701511"][COLOR="Lime"][B]Build[/B][/COLOR][/URL]-1988 Bronco II 39.5"s and stuff [URL="http://pirate4x4.com/forum/showthread.php?p=13034565#post13034565"][COLOR="Lime"][B]TTB Dana 35 for sale![/B][/COLOR][/URL] Hello people, would you like me to murder you? I'm an offroad enthusiast! -Jeremy Clarkson Last edited by BigDusty; 10-01-2008 at 04:15 PM. |
Member # 51243
Not for sure on this, but I believe that the 5.38 (which is relatively new on the market) is ONLY a thick cut gear. But double check on that. Which means you will need a 4.10 and down carrier to work with that gear, if that is the case.
It it has a 4.56 carrier in it, the thick cut gears won't work on that carrier. In any case, figure out what ratio you got an proceed. Look up Randys Ring and Pinion and ask them about the 5.38 being thick cut or if it comes standard cut, as its a relatively new 14 bolt ratio. My friend just installed a 14 bolt and new 5.38s in his Jeep and the from what he told me, the 5.38 only came in a thick cut version.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] Last edited by GMCTruxrule; 10-01-2008 at 11:07 PM. |
Devout Newbie Hater
cool, i learned something today...
thanks, guys.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
