5.3 Vortec & SM465 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2008, 08:26 PM   #1 (permalink)
Member # 110184
5.3 Vortec & SM465
Anybody done this? I need to know what bell housing i would need to mate an SM 465 to a Vortec 5.3. I'm running an Atlas II 4.3 behind them, but I need to know the bell housing or part number. Any help greatly appreciated, THANKS!
Life is tough, it's even tougher when you're stupid.- John Wayne
91 YJ, 5.3, TH400, Atlas 3.8, 35 spl 60's f&r
Pick up your trash you nancy little bastards or sell that shit and go buy a fawkin low rider so you can be around more of your own kind! :flipoff:
mrtoddb is offline   Reply With Quote Quick reply to this message
Old 10-02-2008, 09:46 PM   #2 (permalink)
Member # 55879
I have personally have not heard of anybody using a 5.3L with a manual trans but that is not say it canít be done or hasnít been done. GM didnít offer the 5.3L with a manual trans in any vehicle. I am sure it had to do more with emissions than anything.
The 5.3L is physically no different from a 4.8L or 6.0L so I wouldnít see any reason why you could not use a 6.0L flywheel , pilot bearing and the original 465 bellhousing. I am using my original 465 bellhousing on an 2002 8.1L with a 1978 spec Centerforce clutch and pressure plate in my rig. Chevrolet V8 bellhousings have been the same for well over 50 years.
DirtyLarry is offline   Reply With Quote Quick reply to this message
Old 10-02-2008, 10:00 PM   #3 (permalink)
Member # 110184
Thanks for the info, I appreciate it. Now I know where to start looking at least! Thanks again!
Old 10-02-2008, 10:05 PM   #4 (permalink)
Member # 278
Just an added note, the Vortec(at least mine) has a hole tapped at the very top and one of the two top holes not drilled. This leaves you with 5 bolts holding the bellhousing on.
Advance Adapters told me no problem on my NV4500 to 2004 6.0L.
Lil'John is offline   Reply With Quote Quick reply to this message
Old 10-03-2008, 07:03 AM   #5 (permalink)
Member # 55879
Todd is exactly right. None of the LS series engines have a hole tapped in the 2 oíclock position of the engine bell housing flange. Donít tap it or you will have a nice coolant leak near cylinder #8. The General engineered it to mount with one less bolt on these engines.
Old 10-03-2008, 09:57 AM   #6 (permalink)
GMCTruxrule's Avatar
Member # 51243
Go pick up the August or September, I can't remember which, issue of Car Craft magazine.
They had a whole article on converting those motors for use with old(er) school transmissions.
For example, there is a special throwout bearing needed, as well as a spacer that sets the flywheel 0.4" out from the crank mounting surface.
can't remember all the rest, but check it out, very informative.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote Quick reply to this message
Old 10-03-2008, 10:02 AM   #7 (permalink)
Member # 110184
Will do, thanks!!!!!
Old 11-05-2008, 08:57 PM   #8 (permalink)
Member # 29929
Send a message via Yahoo to kylege
5.3 swap
Hey,
I just swapped in a 5.3 to mate up with the NV4500. You definately should call Advanced Adapters and just talk with them. This engine never had a manual and needs a special pilot bushing and flywheel. Advanced sells a kit and it was a bit pricey but is pretty smooth.
good luck
Who Really Cares
kylege is offline   Reply With Quote Quick reply to this message
Old 11-06-2008, 06:09 AM   #9 (permalink)
Bo185's Avatar
Member # 48545
Originally Posted by kylege View Post
Hey,
good luck
Did you have to do anything to the crank other than install the pilot busing? The 4.8l and 6.0L had manuals behind them but they both have different cranks vs the 5.3L. Why couldn't you use a 4.8l pilot bushing, crank spacer (I believed used on the later ones as the early ones had the solid longer crank) and 6.0L NV4500 flywheel?
I am just shooting from the hip as I have always just used autos.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 11-06-2008, 07:17 AM   #10 (permalink)
Member # 89189
Advance adapters has a complete clutch and flywheel kit just for this application.im using it on my k5.2005 5.3 vortec(6.0 coming soon!)mated to old school sm465 manual trans.
70k5 blazer.6.0vortec.sm465,t-136 2.5t case,hydro strg,2.5t axles, disc brks,16.9x24 v-treads.
tallhoedude is offline   Reply With Quote Quick reply to this message
Old 11-07-2008, 07:09 AM   #11 (permalink)
Member # 29929
pilot
I used AA 2 piece pilot bushing and flywheel kit. I am not sure about the 4.8 or 6.0. It was not cheap but it works great. Good luck
If you have any other questions or need pics i will send you my email.
Who Really Cares
Old 11-07-2008, 07:22 AM   #12 (permalink)
Member # 117823
I used an LS1 flywheel, the sm465 pressure plate (balanced together), the sm465 slave and the ls1 pilot bearring was only pressed in about 65% of the way to make up for some of the .400 of the shorter crank. sofar over 60K miles on the conversion with no issues.
ls1andvortec is offline   Reply With Quote Quick reply to this message
