2000 chevy silverado rear end? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-04-2008, 04:25 PM   #1 (permalink)
FORDPLAY's Avatar
Member # 62032
what axle is in my 2000 chevy silverado 4x4...? i know i have 10 bolt cover...but i tryed to put a new carrier from a 95'ish chevy 4x4 with 3.73's and it will not work..i need to know what carrier it has so i can get a new one my carrier broke ......i tryed the vin at chevy ...thay can tell me anything but it has 3.73's.....
is it a 10 bold ? or what is it.. what carrier do i get ?
FORDPLAY is offline   Reply With Quote Quick reply to this message
Old 10-04-2008, 05:51 PM   #2 (permalink)
Member # 114474
10 bolt should be a 8.6 ring Gear carrier for 30 spline axles. I think the older 10 bolts had like a 27 spline axles.
1FastBrick is offline   Reply With Quote Quick reply to this message
Old 10-04-2008, 06:13 PM   #3 (permalink)
Member # 343
Yes, the newer one is 8.6" the prior ones were 8.5" I am not sure if they'll interchange....someone will post up whether they will or not.
EDIT: To answer your last question....Yes, it is still called a 10 bolt....but an 8.6" 30 spline vs. the prior 8.5" 30 spline.
cj8scrambld is offline   Reply With Quote Quick reply to this message
Old 10-05-2008, 07:26 AM   #4 (permalink)
Member # 11016
I could be wrong, I am a little jazzed up on pain meds, but I think the later 8.6 has bigger carrier bearings. That should mean the earlier carrier would need special bearings for it to fit. I know thay make bearings to go the other way, late carrier in early housing, but not sure of doing it the other way around. You alos have the spline difference, so you are probably better off getting the wright carrier fro your dif.
ALEX Bronco is offline   Reply With Quote Quick reply to this message
Old 10-05-2008, 07:50 PM   #5 (permalink)
FORDPLAY's Avatar
Member # 62032
Exclamation
i looked all over for a 8.6" carrier and theres nuthing but i see lots of 8.5" and the detroit locker site has a locker that says " works with 8.5-8.6" so ....are thay the same carrier and gear .. just diff bearings?
Old 10-05-2008, 09:20 PM   #6 (permalink)
FORDPLAY's Avatar
Member # 62032
or will i be better off geting a 6 lug 14 bolt out of a 96 or so 2500? do you all know if it will miss with the EBS or will it be ok? all i will need to do is get a new u-jont and mite have to move the spring pads ????
Old 10-05-2008, 09:27 PM   #7 (permalink)
Member # 89098
Send a message via MSN to Gerb
My thought went to the 6lug 14b. Should be a bolt in(except the u-joint) Does your diff have speed/ABS sensor/s?
IF YOUR GONNA BE DUMB THAN YOU GOTTA BE TOUGH
Gerb is offline   Reply With Quote Quick reply to this message
Old 10-05-2008, 09:55 PM   #8 (permalink)
FORDPLAY's Avatar
Member # 62032
ABS ...i dont know about speed ...i know there is a wire going to the back diff..
Old 10-05-2008, 10:21 PM   #9 (permalink)
Member # 89098
The one i have doesn't have a sensor on it. It is a 96 or 97.They are kinda spendy compared to just getting the right carrier for the diff you have. around here they go for about $500.00 on average. Got it for my Tahoe for when I lift it.(soon i hope)
Old 05-31-2010, 10:30 AM   #10 (permalink)
Member # 161353
does any have a rear end for sale
hey does any have or know someone that has complete rear end with a gt4 gear ratio for a 2000 chevy silverado
thanks cody
liftedchevyguy93 is offline   Reply With Quote Quick reply to this message
