th350 questions... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2008, 04:03 PM   #1 (permalink)
Member # 111714
th350 questions...
So I just picked up a 77 chevy 1/2 ton, 350/350/203 drivetrain, 3.73 in the axles, with 35" tires. Im hitting 3000 rpm at about 55 mph, Im thinking that should be a little lower with the stock gears. Tranny doesn't feel like its slipping when Im accellerating, but could it still be when Im up to speed?
And second question- the damn thing wont upshift till about 4000 rpm, wtf is that? Once it gets there, it shifts fine, but as far as i can tell itll stay at 3500 all day without doing anything. Would a shift kit fix this? That can't be normal. Supposedly the tranny was rebuilt about 30,000 miles ago, but I know its been low on fluid a couple of times in the last few years. I don't know much about transmissions, so Im really not sure where to start, and the search didn't turn up anything.
Oh yeah, if this should be in the newbie section, let me know. Figured Id get more advice here though.
Tyler C is offline   Reply With Quote
Old 11-20-2008, 04:58 PM   #2 (permalink)
Member # 106427
You should be around 1970 in rpms at 55. Check the modulator that has the vacume line attatched to the side of the tranny, and the vacume line for cracks, and see if you have vacume.
later
jenks
jenks21 is offline   Reply With Quote
Old 11-20-2008, 07:03 PM   #3 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
yeah either its not shifting out of second or your speedo is all jacked up. i ran 410s and 33s and around 55 i was at like 2500
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 11-20-2008, 07:18 PM   #4 (permalink)
Big Worm
jenks's Avatar
Member # 118119
later
jenks
x2 thats exactly what I would check first. If the line is disconnect or the module is bad that would cause a shifting problem. I had the same thing in my old truck and at 50 I was about 2000 rpm and at 70 it was 3000 rpm
jenks is offline   Reply With Quote
Old 11-20-2008, 09:40 PM   #5 (permalink)
Member # 111714
Thanks guys. Unfortunately I won't be needing that advice anymore, just wrecked the truck Just bought it too... oh well.
