Pile of s10 blazer build, low lift, full widths
37K views 23 replies 13 participants last post by  85stanky
#1 · (Edited)
Now that I actually have some pictures of my rig I might as well start a build thread.
It started out as a '94 s10 blazer 4.3 vortech, auto trans, auto shift t-case. Bought it for $100. When I bought it the starter would turn a little bit and then lock up. I bought it in January 08, first time it drove more than on and off a trailer was a week ago for some yard wheeling, pics at the end of the thread.
The original plan was 31" tsl's, a welded rear and beat the crap out of it. 1 thing lead to another and the 31's got sold, IFS fell on the ground along with the auto trans and t-case. It turns out the high pressure fuel line under the intake was cracked filling the cylinders with gas ad hydrolocking the motor, $50 for the fuel line and some tune up parts and the motor ran.
I had a set of 36" tsl's, picked up a high boy 44/60 for $100, some 15x8 8 luggers for $50, a free nv3500/ 231, parts truck with a manual trans, pedals, and fly wheel for $50. At this point I was going to swap in some radius arms and coils and try and keep it as a budget beater. After spending a day trying to figure out how the heck I was going to mount coils on the basakwards s10 frame I decided on leafs and pulled them out of my parts truck. 1 thing lead to another and I started spending some $$ on parts to make it a better wheeler.
It's a pretty standard s10 build with a couple different mods. Keep in mind these pictures are as it was being built, some of them are from the summer, the only wheeling it has seen is in my yard so far. I don't have current/ painted pics of some of the mods that are finished.
The front suspension uses s10 rear leafs, to keep it low I mounted the leaf springs up in the frame and moved the axle forward about 7". The front axle is a stupid external lock out ford 44. It's pretty much stock with 4.10 gears, new spicer joints tacked in, and a mild shave/ "toung" to aid with sliding over rocks. I used standard 1/2 ton gm calipers. I "modified" some gm caliper brackets to work with the ford rotors and 15 inch wheels, I can't wait to swap out the external lockout hubs and caliper brackets for standard internal lockout gm stuff.
The shackle mounts are welded to the front bumper built out of 1/4" plate
#2 · (Edited)
For steering I used an awd astro box, moved the mount over with some 1.5"x4" tubing sleved with 1/2" pipe and plated with 1/4" plate. It clears the tires just fine and allowed for a good steering shaft angle. The steering shaft got sortened and I used some lines and compression fittings I had in the collection to make it work, using something like a scout 2 steering box may have worked better. It's a little ******* but it works, at this point I was still on a college budget and was really trying to use what I had.
For steering linkages I splurged and used sky mfg. 7/8" high steer arms, .250 wall dom, and 1 ton ends. To get lock to lock steering I used a scout 2 pitman arm. My last straight axled s10 had a waggy arm and it wasn't long enough to get lock to lock steering. If I ever upgrade to stronger axle joints I should be able to turn the steering stops in a little bit and get more steering angle. Right now it turns like a dream compared to the other straight axled s10's i've had/ ridden in.
For the rear axle I used a ff 30 spline ford 60, nothing special. Shaved the axle a little bit and added a "toung" to help sliding off of rocks. . The rear axle was also moved back 1.5" to gain some room for tires. The shocks mounts are built out of 1/4" plate. They are above the bottom of the axle tube for clearance, upper shock mounts are just a piece of 1/2" pipe welded to the frame. Rear shocks are mounted now. The wrong sized crooked u-bolts are off and a set of u-bolts right right size are now on it. I also added 2" blocks for now to help level the truck out. I'm not a my truck has x inches of lift person but i'm guessing the s10 is around 6-7" of lift in the back right now with a spring over on sagged springs, a 2" block, and a bigger axle tube. Adventually I'll drop down to a 3/4" or 1" block and some longer shackles.
It has disc brake brackets from ballistic fabrication and 1/2 ton chevy calipers that wern't on in the pics. I tried to build my own caliper brackets and ran in to problems with the calipers rubbing on the wheels, got pissed and my stupidity and cut them off.
#3 · (Edited)
The gas tank got moved up above the frame rails, you can see the underside picture in the post above. The skid is 11 gauge with a skeleton of 11 gauge. I trimmed the floor to allow the tank to poke through the floor, i extened the floor with some 20 gauge and used the stock floor cutout as a cover. The stock fuel lines were able to reach up above the frame. I also added a crossmember to support the front of the gas tank skid. Now you can acess the pump and lines through the back floor, the "cover" is held down with a dozen slef drillers and sealed with some liquid nails.
I built a rear bumper known as the "back porch". The frame is 2x2x1/4" tubing, i cut the rear corrners to gain some clearance. It has 2 d-ring mounts ad a tire carrier bout out of 1 1/4" sch 40. To help pivoit the tire I used a d44 hub and spindle, it need to be finished with a hold down and the spindle welded on, right now it's in the garage till I get a spare.
These are all the pictures I have of mods. Some other mods I did were a new trans crossmember out of 2x2x1/4" square tube, it allows the drive shaft to actually move i'll try and get pics, auto to manual swap, hacked the heck out of the fenders and added a bling bling ricer air filter, got rid of a bunch of junk under the hood like cruise, abs, and ac.
#4 · (Edited)
Here's some yard wheeling pics
Some things that still need to get finished are
-Weld on the glo bead lock kit I have sitting around
-Re-build the t-case because it pops out of low and the chain has about 1/2 a turn of slop, probably add a super short sye kit
-Put in an aluminum summit radiator, the stock radiator jumped into the fan, build a custom shroud
-Front shocks need some mounts
-Rear traction bar, 2x2x1/4" squre tube is sitting at the steel shop for me to pick it up, probably build the crossmember so it can support a belly pan
-Mount my winch on the front bumper
Future Mods
-DD machine doubler, 1350 rear drive shaft, super short sye
-Belly pan
-Cage
-Re-build front dif, Alloy front shafts and a slectable locker
-35 spline rear shafts and spool
-Rocker guards out of 4"x1.5" rect. tubing
#11 ·
looks good man, one suggestion is maybe tie your front shacke plates together to elimiate side to side movement. Also what did you u use for a front d-shaft?
my brother and I built the same rig with same parts and axles. but when it came down to getting a front d-shaft, we decided to find a high pinon housing.
#12 ·
Front shackles could use a cross brace and some thicker material.
My front drive shaft fits good without the need for a high pinion, angle will be even better when the doubler goes in. I'm pretty sure TSL you have a lot more lift than i do causing drive shaft angle issues.
Ordred today a bunch of parts, including:
Super Short SYE
T-case re-build kit and chain
Dana 60 1350 yoke
Traction bar bushings and johnny joint
Aluminum Radiator
Hopefully the by end of december/ early January I'll have a doubler and 1350 rear d-shaft ordered.
I'm in IL for the week visiting my parents, i'll be back in CO saturday and hope to start cooking on it when I get back.
#13 ·
Yeah the doubler will help the angle alot. My front driveshaft angle is still fine with the airbags maxed out which is about 22" of lift (no I don't and won't drive it that high, it is for down travel when the suspension articulates).
#14 ·
QUOTE]
Yah we have more lift due to the way we put our shackes for the front spring towards the back and rigid mounted the front. We have about 27" of belly clearance between ground and transfer case skid, and the 38.5s will rub when stuffed into the wheel wells, so were pretty happy with it.
#18 ·
So no one wants to buy it, I guess I'll finish it. I picked up a second t-case and hope to have the doubler assembled and in this weekend so I can order drive shafts monday.
I ordered up a radiator and have an oil cooler off of a tbi 350 suburban I'm going to try and graft into the blazer. I also have a 16" electric fan I'm going to rig up with a toggle for backup cooling. I plan on bulding a new fan shroud. Can you tell I despise over heating.
I have a set of internal lockout 8 lug gm outers I'm going to swap on to get rid of the stupid external lockouts, big Ford rotors, and cobbled caliper brackets.
It's going to be a busy weekend, the plan is to have the doubler assembled and in, radiator/ fan shroud/ oil cooler/ electric fan in and mounted.
With any luck it will be wheeling some time next month.
#20 ·
Those turn signals are along for the ride, not sure I'm 100% of a fan of them either.
I hate s10's after building a couple. If you are going to build one to the level my s10 is or even more "extreme" (4 link/ coils/ new drive train) ditch the stock frame. All it's really good for is scrap metal and head aches. Nothing is parallel, the rails are different sizes, the frame is really thin.
I'm stuck at work till 5 and then it's on
#21 ·
Well so far the back t-case is ready to go in with a super short sye and new chain. Front case has the front output cut off and the "cover plate" glued on, it looks like a ****ing 4 year old welded the damn thing on, aluminum ****ing sucks.
There's a new radiator in the bed of my pickup. I'm waiting for the t-case to cool so I can bring it home. Time to go home swap the outers on the 44, pull the oil cooler off the suburban and put it on the blazer, bead lock 2 of the 36's so they will hold air, put the 36'. So far things are going well. It was nice to work on the pile. With any luck I'll be ordering drive shafts from Jess monday morning.
#22 ·
So I've made some progess, being sick as can be didn't help.
The doubler is assembled and in.
Drive shafts were ordered this morning, .250 wall tubing, all 1350 joints, long slip front, along with 1350 yokes
Swapped the stupid external lock out hubs for chevy internal lockout hubs, still have to put the lock outs in and pull back off the driver's side to fix 2 stripped out knuckle studs
New radiator mounts are started, should be done by tonight
16" Electric fan for back up cooling is mounted to the rad, switch is mounted right above the gauage cluster so I know when it's on (S10 dashes are designed to be worked on my minature monkies), I ran the wire in the factory loom which was a nighmear, I just need to mount relay and fuse. I'm hoping to not have the typical electric fan problems using a switch with a relay and then 10 gauge wires from the bat to the fan (less than 2 feet) and a 30 amp fuse.
I started bead locking 2 of the 36's, now I'm playing the find a leak, dismout tire with 32 bolts, grind/ weld to fix a leak, remount tire and repeat game.
My drive shafts won't be here till next week, I was hoping they would be here Friday so I could go wheeling this weekend. The goal is to do some local wheeling Friday the 27th and then head down the Buena Vista to run Chinaman's gluch the 28th.
