ls1 oil pan help what is this for? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2008, 06:02 AM   #1 (permalink)
Member # 62903
Send a message via AIM to prostock3
the part in red, what does this do? I got a new pan and seeing if i could either just cap the ends, or loop them to each other.
2009 Twisted Customs buggy (sold :C) -----2001 Donzi 38zx -----2004 Duramax 2500 CC
prostock3 is offline   Reply With Quote
Old 11-25-2008, 06:10 AM   #2 (permalink)
Member # 5021
Your oil filter will screw onto whats on the other side of that. Might want to keep that option.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 11-25-2008, 06:16 AM   #3 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Thats a bad angle. You mean the ports above the oil filter on the outside of the pan? These are oil cooler lines just get a block of plate if not running a cooler.
They should be plugged see below. I can't find the factory plug P/N.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
Old 11-25-2008, 06:16 AM   #4 (permalink)
Member # 62903
i dont want to do relocate the oil filter housing i belive its on the block but i could be wrong cause the motor is not in front of me. i just wanted the pan cause of the baffles in it
Old 11-25-2008, 06:34 AM   #5 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
The filters on the pan on Gen III. The part you ciricled is the oil filter supply and return lines. The part I m talking about is above the filter itself and is held on with to bolts. Is this what you mean?
Old 11-25-2008, 06:40 AM   #6 (permalink)
Member # 62903
i think i get it now, i just looked at my pan wrong at home sorry
Old 11-25-2008, 09:10 AM   #7 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Shit I just looked at some of my stuff and I have a cover off a cracked truck pan you can have!
If you need the cover and bolts, PM me your address and I'll mail it to you. Some people tap it for a oil pressure sender as well.
Old 11-25-2008, 09:22 AM   #8 (permalink)
be cool, baby
tacoma73's Avatar
Member # 17896
You could run a remote filter setup and keep that pan. Is that what you don't want to do???
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly
tacoma73 is offline   Reply With Quote
Old 11-25-2008, 01:09 PM   #9 (permalink)
Member # 62903
nah, i got it all figured out, i didnt know it it was for a dry set up sorry im good you can delete this post if you like
Old 11-25-2008, 01:29 PM   #10 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
FYI this is the LS7 dry sump pan Note the extra ports on the Pass. side.
