91 GMC Sierra Replacing 4wd Acutator - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2008, 05:30 AM   #1 (permalink)
Member # 74405
4HI & 4LO do not work and appears that the actuator is bad. I will be replacing the actuator tonight.
I just want to make sure, but it looks like it just screws in the housing and then just plug in the connector.... correct????
thanks
Chris
98TJ / 30-44 / 35s / Hi-Lines / Zip Lockers
97TJ / D60-14B / 106"WB / 42s
snwchris is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 05:48 AM   #2 (permalink)
USMCNetzel21's Avatar
Member # 113119
Send a message via AIM to USMCNetzel21
Don't know if this will help any:
[IMG][/IMG]
File In Section: 4 Drive Axle
Bulletin No.: 76-43-01A
Date: September, 1998
Subject:
Slow or no Engagement of Front Axle when 4WD is selected (Replace Front Axle Actuator)
Models:
1988-97 Chevrolet and GMC K Models
excluding 1988-93 Models over 8500 # GVW
This bulletin is being revised to add information to the Service Procedure, add a new part number, and include schematics. Please discard Corporate Bulletin Number 76-43-01 (Section 4 - Drive Axle).
Condition
Some owners may comment that the colder the outside temperature is, the longer it takes for the front axle to engage when 4 wheel drive is selected, or the front axle does not engage.
Cause
The front axle engagement actuator is a thermally activated component. Because of this characteristic, the time required for the actuator to complete 4 wheel drive engagement is extended as the temperature drops.
Correction
Replace the front axle actuator and include the applicable wiring harness kit. Refer to the Parts Information in order to determine which wiring harness kit is needed.
1996 model trucks with a build date on or after January 2, 1996 are considered as "961". If the build date of the truck is unknown, verify the 3 character "axle code" on the front axle label in order to determine which wire harness to order.
This new actuator uses a motor to engage the front axle and is not affected by temperature. On 1988-93 models with a GVW rating over 8500$, the new actuator cannot be installed and the thermal actuator will remain the service part.
(alldatapro.com)
USMCNetzel21 is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 07:38 PM   #3 (permalink)
Member # 74405
The Dorman replacment actuator has 1 1/2 thread less then the stock, so I can NOT get the threads to engage.
When I match the stock one to the Dorman one they are the same in length, but the thread run out is different in the Dorman replacment.
Chris
Old 12-04-2008, 07:48 AM   #4 (permalink)
Member # 113119
Maybe I am wrong on this one, could you retap/rethread it to make the new one work??? Not trying to be a smartass, just asking.
