Bad Doctor
Member # 86878
The PCM in your Tahoe requires input from the VSS to function properly.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build /forum/chevy/994394-odins-me-too-short-crew-build.html |
Vortec Scout II
It will work with out it it. It just uses the VSS to shift the 4l60 and some idle properties. I am not sure who could tune it out for you. Tunecats use to to it but they got bought out years ago.
Why not a 4l80? It will give you an overdrive and your PCM will control it.
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
playinwithit
Member # 97574
My buddy speaks VERY highly of this guy for any tuning:
ZIPPY Performance Tuning - Michigan
Playin' with my Willys buggy build |
#5 (permalink) | |
Bad Doctor
Member # 86878
Very annoying
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build http://www.pirate4x4.com/forum/showthread.php?t=994394 |
#6 (permalink) | |
Vortec Scout II
I have seen LSx engines have problems with idle and no VSS as well as poor fuel mileage. Oh and he will lose his Speedo as well. And ABS.
Member # 41764
I'd talk to Westers Performance about deleting your VSS.
They were the only ones who knew exactly how to add the 4l80e .bin files to my comp to make it run in place of a 60e when I called. All the other tuners said they weren't sure it was possible.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5 Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between No one is ever gone if they are always remembered. JasonPayneMemorial |
Member # 100143
thanks guys iv looked in to it a bitt and iv been told that i coild have some problems if i just unplug the trans so iv tested it out and the motor will barely run when i plug it back in its fine.so im going to go with propane.
