Member # 44090
dana axle question
Hi guys,
need to pick your brains, got my self some axles, i think they may be Dana 44, they came off a 1979 Chevy Blazer K5, on the logbook for the vehical, it states that it had a 2.8 litre engine in, although it came with a 5.7 v8!, anyway it has 10 bolts holding the diffpan on. I tried to take pictures with my phone but it kept saying it was busy, how the hell can my camera be busy..... |
Member # 121194
In '79 the front axle should be a GM Corporate 10 bolt, your rear axle could be another 10 bolt or a 12 bolt.
Never seen a 2.8 in a full size, its a dog of a motor in a mini truck so I don't think that GM would waste the effort putting it in a k5. Was this a Blazer built for the UK or one that made its way over there some other way? If its right hand drive you should post some pictures, that would be kinda interesting I think. -Dane |
AllUpInYourFace
Member # 72951
All dana axles have the model cast into the center section. Iicr its on the lower right or left of the center section. This should help you determine what axles you have. Notice the little "ears" on the bottom of the 10bolt. Those usually give it away.
http://www.coloradok5.com/axleguide.shtml |
skullfuckery
Member # 29016
d44 after 75[non flattop pside] are also on the bottom.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#9 (permalink) | |
Member # 44090
next question...how strong are they, will they cope with 37 inch creepy crawlers driven enthusiastically! mostly in mud. Last edited by UK Tinker; 01-18-2009 at 08:14 AM. |
skullfuckery
Member # 29016
mud, mhe ok theyre maxing the axle out but i should last for a while, espeicaly with an auto tranny.
ive run into the motor id issue before. 2.8 did not exist until mid 80's. the guys at pepboys tried to tell me that my 77 3/4t came with a 4.3 "by the vin code......"
