'85 pickup electrical problems. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2009, 01:55 PM   #1 (permalink)
Dana 44 Polisher
Member # 13731
I have an 1985 Chevy pickup with some weird electrical gremlins. I'm a newb to Chevy's but not gremlins... I got the truck as is and none of the stuff worked then either.
Problems:
No headlights - but the running lights and turn/stop lights work.
No heater/fan.
Wipers barely move.
Power windows don't do jack either.
I'm sure some of the other power items don't work -- but I just need the lights and heater for now.
I have checked the fuses under the dash -- nothing obviously blown. I pulled of the big self resetting fuses for the headlights and heater fan and banged them around, clean off the connections and put them back, even switched them around. No change. Truck starts and runs, drives ans stops...
So what am I missing?
uglyscout is offline   Reply With Quote
Old 01-27-2009, 01:58 PM   #2 (permalink)
Member # 35044
You check the bulds and blower motor ? How bout the grounds ? Do you have 12 volts going to them?
dheavychevy38 is offline   Reply With Quote
Old 01-28-2009, 12:39 PM   #3 (permalink)
Ramble On
Shawnboy's Avatar
Member # 9545
Fuse links?
"If you don't believe your country
should come before yourself,
the best thing for your country,
is go live somewhere else."
Help rescue a Springer http://www.srecc.org/page1.php
Shawnboy is offline   Reply With Quote
Old 01-28-2009, 04:13 PM   #4 (permalink)
Dana 44 Polisher
Member # 13731
Originally Posted by Shawnboy View Post
Fuse links?
Where would I find said fusible links?
Old 01-28-2009, 04:16 PM   #5 (permalink)
Member # 121196
x2 on the grounds
Traction is offline   Reply With Quote
Old 01-28-2009, 09:16 PM   #6 (permalink)
Ramble On
Shawnboy's Avatar
Member # 9545
Should be on the firewall near the top. GOOGLE it.
Old 01-28-2009, 09:58 PM   #7 (permalink)
Banned
trkklr77's Avatar
Member # 29016
head lights have there own ground that goes from the light to the core support.
besure the power window realy is grounded, mine wasnt and that was the main reason the p/o got rid of it " jacked elec system"
swap out the wiper switch, the super cool factory 75' variable switch i have sucks. swaped it out and everything was fine.
Old 01-28-2009, 10:35 PM   #8 (permalink)
ChevyGal's Avatar
Member # 4033
On the power windows, make sure they aren't just so crapped up they won't roll up or down. I had to take the door panels off, clean up the rails, or whatever they are called that windows go up and down on. They were caked with just crap that had built up so they wouldn't let the window move at all. After that they worked fine.
Needs more cowbell!
ChevyGal is offline   Reply With Quote
