What would cause a TBI 350 to idle poorly? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2009, 08:32 AM   #1 (permalink)
Member # 95938
i'm going to have a look at a tbi injected 350 this weekend to swap into my CJ7. the guy that owns it converted it from carb to tbi himself using a factory gm computer and wiring harness. he is a mechanic by trade and the motor itself seems to be pretty healthy with about 15k on it and a mild cam.
the thing is, it won't idle until it's warmed up a bit. you need to keep your foot on the gas for a minute or 2 until it warms up enough so it doesn't stall. he just ordered and installed a new chip hoping to correct the problem, but it doesn't seem to have cured the idle issue. he said it has more power than it did before, quite a noticeable difference he says, but it still doesn't want to idle until it's warmed up. after it's warm, it idles fine. i've seen this motor once last fall and it had the same behavior with not idling when first started. but after a couple minutes it's fine. any ideas what would be causing this? the chip perhaps? the first one (that was just swapped out) as far as i know was the stock factory chip which wouldn't be tuned for the mild cam that's in there. but this new one was programmed roughly to specs to match the cam. he couldn't remember the exact specs on the cam he installed so he tried to get as close as possible when he ordered the new chip. i know next to nothing about chevy motors so any insight would be greatly appreciated.
dt5150 is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 08:38 AM   #2 (permalink)
Member # 41969
possibly the throttle position sensor or the idle air controls? Thats the only 2 things I can think of. Probably more likely the idle air control on the throttle body.
08 LTZ Duramax
Top Shop Champion Spring 2006-Team Toumbs Repair
Top Shop Champion Fall 2006---Team Toumbs Repair
Originally Posted by Dan Dibble
"In my opinion this is a motor sport so I like to have one. Any more questions "
Dan
botiejeep is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 08:40 AM   #3 (permalink)
Member # 95938
thanks botie...
Old 02-10-2009, 08:58 AM   #4 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
The stock chip should work fine with a mild cam. My 93tbi has an edelbrock cam in it with the stock chip and it runs just fine. That shouldn't cause idle problems.
Along with what botie said I would check to make sure the injectors were clean.
Also, ask the guy what the TB came off of, 4.3, 5.0, 5.7? Same with the computer and the year of the computer. The different TB's all had different sized injectors, and there were different cpmputers used throughout the years. He would have had to know the year of the computer when he ordered the new chip.
04 Ram 1500 qc D60 AAM11.5 4.88's bilstein 9300s
Hemi 40" Nitto... and most importantly A/C for Tx wheeling!
mudskipper4x4 is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 09:11 AM   #5 (permalink)
Member # 123551
x2 with the throttle position and idle air sensors.
and i have a rv cam on my tbi wih stock chip and runs fine, PO installed it, but ive never had an issue with rough idle
90 Jimmy 350/465/205/60/14/42's
04 Sierra Duramax Twin Turbo ZF6 on 36's
I work hard for a living, millions on welfare depend on me...
brooks294x4 is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 09:12 AM   #6 (permalink)
Member # 13731
TPS -- my buddy had a very similar problem. It almost wouldn't start when cold.
We plugged in a scanner and it said the TPS was bad and reading something like 90% throttle at idle -- probably enough the set the 'clear flood' parameter when you try and start it. If it gets the clear flood signal it shuts off the injectors when you crank it and it will not start/barely start/not idle/etc.
uglyscout is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 09:24 AM   #7 (permalink)
Member # 95938
good info, many thanks fellas.
ugly, what was the fix?
Old 02-10-2009, 10:37 AM   #8 (permalink)
Binder's Avatar
Member # 1684
Best thing you could do is go here and look through the FAQ. Find the initial setup procedures and make sure they were done correctly, odds are they weren't. If that doesn't help then most likely the chip program. There again on that board you can ask for help with the chip..
S.N.O.R.T.
Binder is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 10:57 AM   #9 (permalink)
Member # 53692
I've seen the gasket between the throttle body and intake give out on a couple vehicles and cause a lot of trouble. You might try spraying carb cleaner around the throttle body with the air cleaner still on and see if it changes the idle any. If you have some kind of vacuum leak it should idle up. good luck
fcduffy76 is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 10:59 AM   #10 (permalink)
Member # 95938
thanks binder, i'll check it out.
Old 02-10-2009, 11:01 AM   #11 (permalink)
Member # 95938
ah.. vacuum leak.. hadn't thought of that. but would that still affect it even after the engine was warm? maybe just not as noticable?
Old 02-10-2009, 04:12 PM   #12 (permalink)
Member # 123551
if you had a vacuum leak it would affect idle at all times, hot or cold, it would just go away when you gave it gas..
Old 02-11-2009, 06:19 AM   #13 (permalink)
Member # 95938
that's what i was thinking, but didn't know if it would subside some once the motor was warm.
Old 02-11-2009, 06:52 PM   #14 (permalink)
79chevy39.5's's Avatar
Member # 67935
what caused mine to run shitty was the rockers too far outta ajustment
79chevy39.5's is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 07:09 PM   #15 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
Actually, on those gasket leaks it can go away once the engine is warm. The aluminum intake and throttle body expand more and faster than the steel bolts holding it down. The intake and TB expand and can seal up a marginal TB gasket. I know it sounds far fetched, but I've seen it with my own eyes. Of course our extreme temperature swings in this neck of the woods can do goofy stuff like that. That kind of stuff can be a real bastard to figure out.
*edit* Oh yeah...and have you plugged a scan tool in to see the datastream? I'd like to know what your CTS is reading. A faulty CTS will make the cold mixture lean and will not advance the timing enough for a cold engine. Opening the throttle some while warming it up would offset both of those.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 07:16 PM   #16 (permalink)
Member # 129378
i agree the gasket between the throttle body and intake was my problem just the other day
sazuki2 is offline   Reply With Quote Quick reply to this message
Old 02-12-2009, 08:15 AM   #17 (permalink)
Member # 95938
thanks guys, gives me some good questions to ask him. i appreciate the help.
Old 02-12-2009, 10:07 AM   #18 (permalink)
Member # 33524
Send a message via Yahoo to TallGuy
Mine was idling high, replaced the gasket and tried different chips. Turned out to be the Idle Air Control valve. Good luck!
TallGuy is offline   Reply With Quote Quick reply to this message
Old 02-12-2009, 10:33 AM   #19 (permalink)
M@
Member # 113615
My Dads IAC valve would get stuck closed and not go into high idle when cold. I would just spray some carb cleaner in there (IAC port) while it was running so that it would burn off instead of sitting in the cyclinder. That worked pretty well the two times I had to do it. If I had taken the IAC off I might not have had to do it again though.
M@ is offline   Reply With Quote Quick reply to this message
Old 02-12-2009, 10:41 AM   #20 (permalink)
chrissybf86's Avatar
Member # 68634
do you know what cam???
does it go away when it is warm?
what is your fuel psi?
chipped ecu?
mine ran funny cause it is like 10:1 comp and a 272 cam i up graded to a holly thottle body and i tuned my ecu.
07 jku 3.5/35s / camaro track project
Adrenaline off road & Track
chrissybf86 is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 08:59 AM   #21 (permalink)
Member # 14584
Is the closed loop, open loop, circut hooked up/working? If the computer dont know the engines cold it wont richen the mixture for you.
Like a carb without a choke.
Yes my truck is environmentally friendly.
It lets most of the environment in the truck with you!
6869704x4 is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 06:05 AM   #22 (permalink)
Member # 190082
hi, i've read all this and for me i have the same problem with my 350 TBI 1994.
it's in a gmc sierra 1994 5,7L
I've change:
cap + rotor
Spark plug and wire
Egr valve
engine coolant sensor
I've clean the IAC valve and the throttle body and i put a new gasket.
i don't know what to do next and my problem is when i'm in park ou in drive and my engine is hot, i have a rough idle but it never stall.
thanks
jo714 is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 08:33 AM   #23 (permalink)
chevy4x4truggy's Avatar
Member # 189419
If it was a vacuum it should be idling high all the time. Yes there is a chance that once it heats up the throttle body expands and seals the leak but not with in 2 mins... My guess is the coolant temp sensor is to blame.. If you don't have a scanner to read the computer then just toss one in, I think they are like 8 bucks! Also get a can of carb cleaner and spray the base of the throttle body to see if the idle changes when it's cold. That will tell you if there is a vacuum leak.. But my money is on the coolant temp sensor..
Keep us posted.
89 Chevy full size Truggy in the makes!
chevy4x4truggy is offline   Reply With Quote Quick reply to this message
Old 11-01-2011, 07:00 AM   #24 (permalink)
Member # 193566
350 tbi idle
I bought my jeep with the 350 already in it, ok with that said my IAC is bad i tested it and when i cover the hole my idle come back to where it needs to be. I bought a new one and installed and its not working. I read where you need to reset it via the underdash port so it can "find home" or something. The problem is i dont know if that port is still their cant find it any help would be great..
lawson1603 is offline   Reply With Quote Quick reply to this message
