How to remove airbag from steering wheel? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-24-2009, 10:44 PM   #1 (permalink)
GMCTruxrule's Avatar
Member # 51243
My wiper/turn signal switch in my 05 Colorado broke internally, so, $240 later, I got the new switch.
I can't for the life of me figure out how to remove the airbag from the steering wheel. I see these little clips inside the viewholes on either side of the steering wheel back, and have pushed on and pried on them, but haven't succeeded in removing it.
I been all over the internet tonight looking for an answer, with no success.
Any chance any of you know how the airbag gets removed?
Thanks in advance.
Lucas
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote Quick reply to this message
Old 02-24-2009, 11:03 PM   #2 (permalink)
Member # 128763
I don't know if this helps.
http://www.autosmanual.com/863/gm-ai...rocedures.html
http://www.grantproducts.com/files/i...7555-00-01.pdf
BIGBLUETURD is offline   Reply With Quote Quick reply to this message
Old 02-24-2009, 11:06 PM   #3 (permalink)
trkklr77's Avatar
Member # 29016
hit a pole.
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 02-24-2009, 11:19 PM   #4 (permalink)
Member # 51243
Bigblue, that might work, I will give it a try tomorrow when I have some light. Thank you.
And Trkklr,
Old 02-24-2009, 11:57 PM   #5 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Originally Posted by trkklr77 View Post
hit a pole.
What did the polish people ever do to you??
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 12:17 AM   #6 (permalink)
mj
Member # 1919
they musta done something,
the RCMP kill them in the airport as soon as they get off the plane here.
mj is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 12:21 AM   #7 (permalink)
Stuntopts's Avatar
Member # 106813
Send a message via AIM to Stuntopts Send a message via MSN to Stuntopts Send a message via Yahoo to Stuntopts
I saw that news report...
"It's a 350 or, for those of you who are left- handed, a 5.7"
Stuntopts is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 01:34 AM   #8 (permalink)
Member # 55444
If I recall correctly those clips are't what you want. There should be a couple other small holes on the backside with *I believe* torx head screws, 4 I think.
If those holes are what I think the are, it's the vent opening for when the airbag is deployed.
Also, check a manual for your truck, disconnect the battery and let it sit for a few minutes, and there should be a plug at the base of the dash with a Bright yellow safety clip that you're supposed to disconnect first, so you don't chance the airbag going off.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 04:17 PM   #9 (permalink)
Member # 115320
Hey squid, did you get rid of the BIG BOYS truck for a little grocery getter?
ORWDon is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 04:46 PM   #10 (permalink)
Member # 51243
Don...hell no. The wifes truck.
Old 02-25-2009, 04:51 PM   #11 (permalink)
Member # 73413
you have to release the spring clips through the access holes in the back of the wheel. It is a pain, but you have to push them both inwards.
Bansheestu is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 04:52 PM   #12 (permalink)
Member # 128384
yes, and yes. the screws go in from the back side. im not sure how many there are.
but i think it'll unplug right at the airbag. once u get the screws out, theres prob gonna be a couple small plugs. but, i suggest disconnecting the battery ATLEAST 3 minutes, before u even touch it.
nevada is offline   Reply With Quote Quick reply to this message
Old 02-25-2009, 09:29 PM   #13 (permalink)
Member # 73413
I have access to all factory service manuals at my shop and have done several of these. All you have to do is release the spring clips. It is a bitch, but that is how it is done on this exact year, make, and model!! Do one at a time, when you release one, pull out on the airbag on that side to keep it from clipping itself back in while you release the other.
