Member # 130431
14 bolt ?
hey guy i got a 14 bolt that i put under my k10 and im trying to find out how to to get a set of 5.13 gears to fit. the axel has 4.56 in now that it came from the facory with and the stock locker. im under the impression that i cant get any lower gears without getting a new locker/carrier. if so any part numbers on lockers around $500 would be apreciated thanx guys.
#3 (permalink) | |
Member # 6704
![]() Just go to the junkyard and grab an open 4.10 & down carrier, pick up some of the readily available 5.38 thick gears and slap a Detroit in it. If you pay more than $500 for a 14b Detroit.... you're getting fleeced.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. Last edited by Mechanos; 02-25-2009 at 01:54 PM. Reason: I can't read |
Who?????
Member # 64846
Maybe he has a 14FF out of a CUCV with stock 4.56 and a Detroit? What vehicle did the axle come from?
Member # 6704
Didn't think of that. But if that was the case, it would still be easy/cheap to transfer the Detroit from the 4.56 & up carrier to a 4.10 & down carrier and pick up a set of readily available thick gears.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
skullfuckery
Member # 29016
uh, they make thick and thin cut gears, buy thin gears and install.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 51243
I have never seen a 5.38 thin gear for the 14 bolt.
Correct me if I am wrong, but I'm pretty sure that they only come in thick cut.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
skullfuckery
Member # 29016
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP Last edited by trkklr77; 02-25-2009 at 10:28 AM. |
Member # 130431
well i was told it came out of a mid 80s diesel srw k30 and so far as what locker is in it ill have to dig up a picture. i wasnt aware they came with different brands.but reading the tech article on the arb im thinking i wont to get one for my 14 and 60. If someone post a picture of what they think ive got i can id it. o yea and it a old style 14 without all the cast fins if that helps.
#11 (permalink) | |
Member # 113084
Chevy Truggy...5.3/350/203/205/d60/14b |
#12 (permalink) |
Member # 130431
o yea guys and forget what i said about 500, im not cutting corners anywere else so let me rephrase my first question with. yall help me build my 14 to handle my 44s like there go cart tires without losing my ability to go 60 mph.
#13 (permalink) | |
Member # 51243
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] Last edited by GMCTruxrule; 02-25-2009 at 11:54 AM. |
#14 (permalink) |
Member # 123438
ok 4.10 and numerically lower gears use a 4.10 carrier. 4.56 and numerically higher gears use a 4.56 carrier. Thick cut gearsets are designed to use 4.56 and numerically higher gears in a 4.10 carrier.(saving u from having to buy a 4.56 carrier)
The problem u have is that u need an open carrier for ur locker. so your going to have to buy a carrier. u can get a 4.56 carrier and then buy "regular" gears or u can get a 4.10 carrier (alot easier to come by than 4.56)and buy thick cut gears. Id suggest a detroit for the rear and an arb for the front. Last edited by Hellbilly Delux; 03-01-2009 at 05:45 PM. |
#15 (permalink) |
Member # 51243
Its 4.10 and numerically lower, 4.56 and numerically higher.
But you got the idea.
#16 (permalink) |
skullfuckery
Member # 29016
you should read the first post again.
#17 (permalink) |
Member # 51243
I know he was talking about 5.13. Good, great.
I was talking about 5.38 gears not having a thin cut option. Because JpSuperDuty was talking about getting 5.38 gears without changin carriers, (second post) but coreylee has a 4.56 carrier right now. (OP) It won't work like that. So, whatever, maybe this thread got off on a tangent.
#18 (permalink) |
skullfuckery
Member # 29016
mhe, since it is still somewhat on par even though it iwas not what the o/p wanted but you are right, randy's has no listing for a thin 5.38 and 2 for thick by different manufact.
#19 (permalink) | |
Member # 86552
#20 (permalink) |
wannabe
Member # 129373
gearz
Hey I personaly have a 14FF with 5.13 "thin" gears you can get them from randy's they are more expensive(335.30) than the thick because they are OEM. They are super quite though because of being OEM. For strength they are plenty strong, they are still thicker than most anyother axle ring gear.
If money is not a factor put a ARB front and back cause you say your still driving on the street. the selectible locker will save your "44's" on the street. If it is a problem search for a used set of OEM 5.13 gears if you have an open carrier get a detriot and problem solved or maybe you already have a detroit. I found my set for 150.00 from Offroad design it was Extra they had laying around. RANDY'S PART # GM 14-513 PM me if you need help
97' TJ Gone wild! http://www.pirate4x4.com/forum/showt...973&highlight= "Everyone has a plan until they get punched in the mouth." Last edited by joshua1086; 02-26-2009 at 03:50 AM. |
#21 (permalink) |
Member # 130431
well my buld is looking something like this 85 short k10,about 10" L78 big block(some high compression forged bb i had around)and im ditching my current stock th350/208 for a fully built low geared th400 with a lowmax 205 twin stick ,high angle rear and one of my uncles front shaft 1410 joints on everything,44,18.5,16.5 tsl and my 60/14 combo. i really like arb's idea of open until u need it. im bye all means not trying to build a grocery getter or a street machine,but my local playground are within a 20 minute country road away and i havent a personal hauler or trailer for that matter.
#22 (permalink) |
skullfuckery
Member # 29016
i dotn think you need the 5.13's
4.56 and 44"s would work well. i have a bbc, 4.56 and 38" i am way over geared for my hp level, and thats mild hp 275ish.
#24 (permalink) |
skullfuckery
Member # 29016
i run 38" at 3k and 70[gps verified]. and with a bbc i could be around 2k and pull the same load.
the bbc will love the extra load, its not like a sbc. i have a doubler and i will probably be going back to 4.10's and 39"s.
#25 (permalink) | |
Member # 123438
5.38s are really low if u dont have an overdrive tranny. (for the road) For any newbies reading this have a search for a good tire and gear calculator. Its a great way to figure out what gears u want for what tires and saves asking alot of silly questions.
