Member # 1655
wheel stud part #'s for 14 bolt disc swap
Anyone have any part numbers handy that has worked well with the swap?? I searched Bella Vista's article but he said he just reused the old ones and planned to update his article when he got part numbers for longer new studs.
I found a bunch on Kragens site for some Gorman studs but not would love to get a part number and get the right ones right off the bat. Any help would be great.
72 COMMANDO/454/TH400/39.5 BOGGERS/DANA 60's/203/300 Doubler......sold |
skullfuckery
Member # 29016
you should search here, there is probably 100+ threads just about which studs to use.
search my name too, i posted ht eones i used several times.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#4 (permalink) | |
Member # 1655
I did search....but nothing on specfic part number came up that I could find. I used "14 bolt disc conversion studs" as the basic search. Thanks for the help I will search your name. Corey...I may just do that mine look to be in fine shape....thanks!
skullfuckery
Member # 29016
the only problem i have run into withthe stock studs was a 2 fold incident.
like others have stated they are a little on the short side. i went out wheeling with blazer-justin, the day before we did the swap at his shop using his tools. when i put the wheels on i ran and impacted them like i have done a 1000x before and since. the problem lie with his impact which i was not used to. any how, was we're drive we hear a grinding and are getting the weird shake from the rig. get out to check and there are lug nuts missing!!! that sucked but was nto the scary shitty parts, the stud that were missing lug nuts had backed out and one had jambed against the rotor and caliper bracket digging a nice gouge right into the brand new rotor. 1 if the knurls were longer it wouldnt have backed out. 2 if i had tightend the nuts better it wouldnt have become an issue in the first place.
Member # 86524
http://pirate4x4.com/forum/showthread.php?t=448216
be aware that if you use the 610-301's you need some red loctite or JB weld or something with em cuz the knurl is a little small. I ended up having to tack weld mine to keep em from spinning.
[URL="http://pirate4x4.com/forum/showthread.php?t=701511"][COLOR="Lime"][B]Build[/B][/COLOR][/URL]-1988 Bronco II 39.5"s and stuff [URL="http://pirate4x4.com/forum/showthread.php?p=13034565#post13034565"][COLOR="Lime"][B]TTB Dana 35 for sale![/B][/COLOR][/URL] Hello people, would you like me to murder you? I'm an offroad enthusiast! -Jeremy Clarkson |
Member # 1655
Thanks for the info guys!
Kitimatdude....what where those studs org application?? I need something to tell the parts monkeys! Any issues at all?? What store did you get them from?? Thanks!
#12 (permalink) |
Member # 2922
Perfect timming,
SO sounds like 610-194 w/ground heads is prefered method. Comming in second is 610-301 w/locktite
Rockin in a Fullsize *****72 K5/Blazer***** |
#14 (permalink) |
Member # 1655
I got all my brake parts today and test fitted the factory srw 14b stud in the rotor. Very sloppy. So looks like the 301.1's are my best option for a tighter fit.
#16 (permalink) |
Member # 62561
I just chucked up the stock ones on a lathe and turned the head down so it sat in the recess of the rotor. It gave me another 1/8".
69 Scout 800, 60F,14bolt,6.0 LQ9/T400/Atlas4.3,39.5 Swampers, 2001 Dodge CTD 6Spd H.O, 4x4, 1965 Unimog [SIZE="4"]"If your buddie was shot in the ass with diamonds, coils and 4 link would be the way to go IMO." [/SIZE] |
#19 (permalink) |
Technical
Member # 20609
I used the search and found the part numbers for these wheel studs. These work perfect with the 14 Bolt Disc Brake Conversion. I have them listed in the picture with part numbers. Hope this helps others.
