350 timing?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-23-2001, 12:01 PM   #1 (permalink)
Member # 119
Post 350 timing??
I have a chevy 350. trying to find tdc so I can time my engine. I know you have to watch the exhaust valve(?) but how exactly do you find it?
I think htat's what it is......My engine has NO power, overheats BAD, letting off the gas I get a pop and sometimes flames out of the exhaust pipe, backfires out of the throttle body, and the headers glow red.
[ 08-23-2001: Message edited by: E*R*O*K ]
1983 Jeep CJ7 "Rockbuggy edition"
jeepinerik is offline   Reply With Quote
Old 08-23-2001, 12:06 PM   #2 (permalink)
Member # 538
Post
Pull the plug on #1. Stick your finger in the hole and turn the engine until you feel compression. Line up the mark on the harmonic balancer with the 0 mark on timing scale.
Lloyd is offline   Reply With Quote
Old 08-23-2001, 12:30 PM   #3 (permalink)
Member # 119
Post
"Stick your finger in the hole" thats a good idea. alot easier than feel for the piston and watching valves move up and down, thanks
Old 08-23-2001, 12:54 PM   #4 (permalink)
Member # 538
Post
For turning the engine I like about 6' of 12 ga. zip cord with a big heavy-duty momentary pushbutton switch on one end and a couple of good sized alligator clips on the other. Hook it to the starter solenoid and you can usually park the engine pretty close to TDC. Sure beats trying to yell at someone in the cab.
Old 08-23-2001, 02:22 PM   #5 (permalink)
Member # 6287
Post
if i was going to guess i would say you probably have the timing advanced an obcene amount, judging by the overheating, but you should also check over all the ignition components, like make sure you dont have a couple plug wires switched
have you taco'd a ten bolt lately?
83 chevy beast 37"boggers
lock rights
powered by white trash
usmc will blow their shit up
jakeoffroad is offline   Reply With Quote
