in need of chevy help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2009, 06:48 PM   #1 (permalink)
Member # 78933
I have a chevy steering column out of an 85 chevy truck, full size. It was an auto w/gear selector on the column, cruise, tilt, and wipers. On the bottom it has 2 plugs, a black one and a white one. I was looking for a wiring description or diagram. So I can get everything to work, from the ignition to the wipers. I don't care about the cruise control. It s in an 88 yj and I have all ford running gear, so I am trying to avoid buying another Hanes manual. I have not had much luck on the internet. Can anyone give me a hand? Thanks Russell
russell720 is offline   Reply With Quote
Old 03-15-2009, 07:32 PM   #2 (permalink)
indytrucks's Avatar
Member # 82470
Send a message via AIM to indytrucks Send a message via Yahoo to indytrucks
Just to clearify, you have an 88 YJ,with all ford running gear, and you want to use an 85 chevy truck column?
indytrucks is offline   Reply With Quote
Old 03-15-2009, 08:23 PM   #3 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
so wtf if he does, it has nothing to do with the running gear.
best bet is to look in www.67-72chevytrucks.com they have a lot of good diagrams.
trkklr77 is online now   Reply With Quote
Old 03-15-2009, 09:29 PM   #4 (permalink)
indytrucks's Avatar
Member # 82470
Don't remember asking your opinion on it douche. I was just clarifying.
Old 03-15-2009, 09:57 PM   #5 (permalink)
Member # 111241
You're lucky I happen to have my GM column Wiring manual from painless.
GM turn signal Section colors and purpose - Factory Colors
Black - Horn
Lt blue - Left Front Turn
Dk. Blue - Right Front Turn
Brn - Hazard Flasher
Purple - Turn Flasher
Yellow - Left Rear Turn
Green - Right Rear Turn
White - Stop Lamp Switch
GM ignition Switch colors and Purpose - factory colors.
Purple/white - Ignition start
Pink - Ign Coil +
Brown - Accessory Fuse Panel
Orange - Ign-switched Fuse panel
Red - Battery B+ (connected to starter or positive battery terminal)***
** there may be 2 thicker Red wires, that need to be connected to power everything.
I dont know if you are using the factory gm ignition switch but I would assume you would if you want the key to work. If you are let me know, I can help you figure out which wires to connect to what tabs. If you have the ign switch pigtails, It will make the job much easier/ cleaner/ safer.
74 Chevy k10 on tons
98 blazer 3 link sas, 50f, rear in the works
Kali-K10 is offline   Reply With Quote
Old 03-15-2009, 11:17 PM   #6 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
I can take some pics of a wiring harness from inside one of the columns if you need that.... but his ^ wiring is correct...
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 03-15-2009, 11:57 PM   #7 (permalink)
Member # 78933
t
Yes I have an 88 yj I bought to do a budget build, since times are a little tight, and my wife is getting ready to kill me over my jeep budgets. So the yj had a 5.0 in it. So I am in the final phase of fuel injecting it. As far as the running gear goes, go with what works and I can find a deal on. Deals is how I ended up with the chevy column. Thank you very much for your help. I do have the two pig tails at the bottom of the column. Those are the black and white ones. I think this is going to be a big help. I"ll keep you updated, and I may need some more help, but won't be until next weekend. Thanks again. Russell-Sparks NV
Old 05-07-2009, 01:16 AM   #8 (permalink)
______________
Corey Young's Avatar
Member # 21622
I have my 1986 column stripped down to just the factory ignition switch, the wires on the two column plugs are:
tan/white stripe (unknown, no power)
orange (hot when key is on for accessories)
red (to bat +)
red (to bat +)
brown (hot when key is on for accessories)
pink (power to Ign Coil )
purple (to starter solenoid)
What wires go where? I searched but couldn't find the right info or diagrams.
Corey Young is offline   Reply With Quote
Old 05-07-2009, 09:18 AM   #9 (permalink)
______________
Member # 21622
That was easy, it only takes 3 wires to use the factory ignition switch.
