Member # 52099
Starter/flywheel help
Having problems with starting my truck. The starter is violently hitting the fly wheel and sparking. This problem just started occuring recently. The motor started great for the first two years it has been in my rig. Then one day out of no where the starter was grinding on the flywheel. I changed the starter twice ( yes i put in the shims )and i still have the same problem. What gives? What do you think the problem is?
You're really wasting your time asking my wife for directions! |
Member # 52872
Sounds to me like when your 1st starter failed and was grinding that it might of damaged your flexplate/flywheel gear. If you changed your starter a couple of times and have same prob you need to pull out starter and closely inspect your ring gear. Make sure you turn motor over by hand and inspect all the way around cause you will only get frigged teeth in a couple of spots.
[COLOR="gray"]Horsepower is like a Condom.....I would rather have it and not need it than to need it and not have it [/COLOR] |
