Member # 131954
Stalling Problem
I ran out of gas last week and since then my 73 will not stay running. It will idle for about 20 seconds perfectly then it will just stall out, if I push the gas it will run rough, I drove it about 13 miles and nothing changed. I have put in a fuel filter because it didn't have one before, I also cleaned the carb, does anybody have any suggestions? Any help would be appreciated.
Thanks |
#3 (permalink) | |
What did you expect?
Member # 119290
actually, i'd pull the fuel cap, and blow air from the front, in case the fuel pickup is coated with crap. if this solves issue, either pull tank and clean, or always keep fuel above 1/2 tank. |
Member # 52872
Even though the mechanical fuel pumps damn near last forever, they can fail once run dry (after a few hundred times in there life.) A plausible thing to consider.
edit: Ohh and running an old carb dry isn't good for it. you could have all kinds of goodies in there once you run it dry and get it going again. Almost sounds like a carb isssue, you said you cleaned it out? Did you take it apart and clean it out?
[COLOR="gray"]Horsepower is like a Condom.....I would rather have it and not need it than to need it and not have it [/COLOR] Last edited by grasshopper77; 03-17-2009 at 12:48 AM. |
Member # 52872
One other thing I was thinking about is if when the carb ran out of gas you also got some crap lodged in there somewhere from the bottom of the float bowls. A trick to try is to get her running and using a rag or summin similar (careful not to lose the rag into the engine
) rev the truck up, 3-4000rpm and hold there and quickly hold rag over top of carb, while still holding throttle. Pull rag off just before it stalls. Do that a few times in a row and see if it clears out. Creates a huge vaccum (suction) and can sometimes draw out some nasties. I have fixed a running problem doing this, but be aware that if that is the case you will eventually need to rebuild the carb.
[COLOR="gray"]Horsepower is like a Condom.....I would rather have it and not need it than to need it and not have it [/COLOR] |
Member # 131954
i dont know what the needle and seat is. i know nothing about carbs, im an import guy that has converted to off roading. i just got done cleaning out the fuel lines and found nothing clogged.
Member # 52872
Try what I said above and see what happens.
#9 (permalink) | |
Member # 52872
![]() You could turn the idle screw way up and see if it stays running long enough to try yourself.
#12 (permalink) |
Member # 128665
FWIW,
When you run a mechanical fuel pump dry, it stretches the diaphragm inside further than it is used to being stretched. If it's an older pump, the rubber diaphragm inside could be getting hard, crusty, and starting to desintigrate. When you ran it out of gas, it's possible some pieces of desintigrating rubber dislodged and found it's way into your carb--especially since you aren't running a filter (shame!). I'd +1 for cleaning the needle/seat assembly. Since it hasn't been mentioned yet, what kind of carb are you dealing with? |
#13 (permalink) |
Member # 51243
Which will then start dumping fuel down into the oil pan. No bueno fo yo moto.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#15 (permalink) | |
Member # 53682
Freedom is only part of the story and half the truth….That is why I recommend that the Statue of Liberty on the East Coast be supplanted by a Statue of Responsibility on the West Coast. Viktor E. Frankl |
#17 (permalink) | |
Member # 131954
#19 (permalink) | ||
Member # 52872
#20 (permalink) |
Member # 131954
ive been trying to get some help locally, with no luck. this is my first car with a carb, i know my stuff on fuel injection, the carb is just a new world to me. im trying to let you guys know everything that is happening that way we can come up with the best diagnosis.
#21 (permalink) | |
Member # 52872
You ask some of the younger guys in the trade to rebuild a carb, even the most simple carb like the edelbrock and they look at you like "what?" You know your fuel injection but don't know where the idle screw is? Even fuel injected vehicles have an idle/air screw. I'm trying man, did you try revving up and clearing out the carb like I said?
#23 (permalink) |
Mobil Man
Member # 45767
You need a mechanic. Your going to set your self on fire!
Just clean your yard...Tube buggy 113" 14blt/60 Propane 350-700R4 rev.man 3.8 Atlas 16" ORI's 42" PitBull Rockers Racelines |
#24 (permalink) |
Member # 52872
sensesfail85...listen up and if you are gonna try it out be careful, cause we're all gettin' a little worried here. You can't set yourself on fire by doing this the worst that would happen is it will stall, or you suck the rag into the intake..
#25 (permalink) |
Mobil Man
Member # 45767
Go with grasshopper. Hand jiving works wanders.
