#126 (permalink) | |
Bad Doctor
Member # 86878
That has been corrected. I worked with Jeff at Ballistic designing that cover (I was the ginea pig) It does come with a fill plug.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build /forum/chevy/994394-odins-me-too-short-crew-build.html |
#129 (permalink) | |
my axle has held up great, i run stock shafts and a welded 3rd with 44's and no issues. I got it with the disk conversion already done/ planning on shaving it soon
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's Section8Krawlers.com Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike |
#130 (permalink) |
Ruiner of the Things
Member # 130031
Has anyone broken one of these things? Thats the question. If so, how and under what setup?
And the axle above, it if has 1/2" studs then its a pre- 1970 axle and you can drill out and press the 9/16" studs in.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps http://www.pirate4x4.com/forum/showt...=781656&page=3 '42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins http://www.pirate4x4.com/forum/tow-r...airstream.html Last edited by AlxJ64; 09-29-2009 at 01:37 PM. |
#131 (permalink) |
Member # 112787
yea i am quite curious to know if anybody has even broken parts on these axles. ive been looking into my front eaton and the only thing i see that i think will break is the outer shaft because theyre similar to 44 shafts
WHEELING: THE MOST FUN YOU CAN HAVE WITH YOUR CLOTHES ON........1985 blazer 1980/82 trazer 02 LB7 2500HD 85 3500 crew cab |
#132 (permalink) |
Got Drivetrain?
Member # 140133
The closest that I have come is to wear the bearings out after 13 years in the mud with seals that barely kept mice out, let alone the mud. Even with all of the bearing rollers missing, it still didn't break - would just lock up every now and again.
This is with cut 44 Boggers, 4.56 gears, 475 HP (per the dyno) and plenty of air time. I have broken most everything that there is to break on my front 60, but never the Eaton.
More driveline parts than you can shake a stick at... http://www.northerndrivetrain.com |
#133 (permalink) |
Member # 106663
I put kinks in the splines on the 17 spline axleshafts I had in the Eaton rear out of a 71 Suburban I swapped into my 73 pu with a pretty powerful big block and a 465. That was after years of towing and plowing snow and getting big loads of firewood, while driving like a maniac that almost never got passed anywhere. I swapped them out when I put a no-spin in. Didn't break them though.
#134 (permalink) | ||||
Super Willie
Member # 19067
Grrrreat tech thread....
I've been trying to gather a bunch of info on these axles, but there is so little out there and even the guys who claim to be experts cannot agree on things, so I'm going to throw some Qs out there, can anyone answer these for sure? First off, does anyone know for sure which year(s) they were introduced? I show 1960 for the H-052 and 1955 for the H-072. I believe that is off by a bit, but the books also show a H-033 and a H-050 that were used in the 50's and 60's. Quote:
Are you sure on the load bolt and brake size being the only difference? There are some who say they've seen the H-052 with the load bolt. I've been told that the 052 and the 072 have a difference Pinion Mtg Depth. Anyone have any insight? Has anyone taken a ring and pinion from a 052 and put it into a 072? or vice-versa? Quote:
Does anyone know what capacity this is referring to? The 052/072s are rated at 11,000lbs and 17,000lbs respectively. I've seen them in the GM manual referred to as a 5200 and a 7200, but no lb. notation afterwards. Quote:
OK, that seems to be a consensus and it makes sense, the load bolt would give it a higher load rating. Quote:
The doubler roller brg is BCA# 5310-WA. The doubler taper brg is BCA# A-1011. ![]() In talking with a few of the 052/072 old timers, they say the tapered brg holds up way better than the roller brg set-up. Gear ratios? It is known and proven that there are 4.10s, 4.57s and 5.14s; supposedly a GM manual shows there to be a 5.83 gearset. Has anyone actually seen the 5.83s or have a set on hand? Pics or it didn't happen. Calling it an Eaton axle has been a big bone of contention from most old-timers I've talked to. They say that Eaton only built the housing, but Saginaw or GM built the 3rd members, ring and pinions and diffs. They call it a GM axle, not an Eaton. They've been an Eaton axle to me ever since I've seen my first one, but some people have gotten their panties all in a bunch when I called it an Eaton.
Tim Lund Yeah, I wear a Kilt... what you're not man enough?! Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market! Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363 |
#135 (permalink) |
I haven't had mine apart, but I do have a 3rd from a '65 C20 [4.57, No-Spin] and one from a '68 C30 motorhome chassis [5.14, open, load bolt, extra oil passage to the pinion].
The 5.83 gears were shown in a service manual, iirc. i think i have that pic somewhere. yep, here it is...it also lists the 5200 and 7200 as capacities, so who knows? Here is also an exploded view. enjoy
:laughing: |
#136 (permalink) | |||||||
Member # 130031
Don't know for sure the latest date but from personal experience I have pulled the non load bolt "052s", from as late back as a 55, and I have pulled "072s", as late back as '60. Next weekend I am going to snag two more 052s with 5.14s and one is detroited. Quote:
![]() Quote:
![]() I would believe that it does. The roller bearing feels like it has a bit more slop in it that the taper. Quote:
Now... I have a question. The hub bearings that are in my axle are the original bearings I believe as the races are Cup shaped and the rollers are all very rounded shaped. They seem to be able to run at nearly any point on the race as its bowl shaped rather than a cone shape. Anyone have any input on this and has anyone replaced the hub bearings with cone and straight taper bearings or are the ones you get from the auto parts store also the cup ones. Supposedly my Advance Auto can get me hub bearings for dirt cheap, but they have to order them and I was just wondering if anyone has done this.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps http://www.pirate4x4.com/forum/showt...=781656&page=3 '42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins http://www.pirate4x4.com/forum/tow-r...airstream.html |
#137 (permalink) |
Super Willie
Member # 19067
Thanks for posting that up Dave, I knew I had seen that posted before, it must have been you.
That answers a few things: Axle Make: Chevrolet Axle Rating: H052 is 5200, H072 is 7200 and it is the larger 1100 and 1500 that were rated 11,00 and 15,00lbs. And the elusive 5.83 ratio. However has anyone ever seen one? The manual says only in the single rear wheel with the HD 3 speed trans.
#138 (permalink) | ||||
Super Willie
Member # 19067
That's a big 10-4. One would assume that anyone who has a load bolt 3rd in their small brake housing probably has had the 3rd swapped at one time and just don't know it. There is also the possibility that GM was assembling their axle and ran out of the 052 3rds so they slapped in a 072 3rd and called it good. Quote:
That would be huuuge! They may be unobtainium, but if we could prove they exist, we'll know that they can be found. Again I'll say pics or it didn't happen and overall pics too to show what model 3rd they are in. Plus another benefit is that IF a set could be found and obtained, then making a run of new R&Ps would be easier. Quote:
65-66 All (Full-Floating) (GM axle) (leaf springs) Inner brg #KD-11786-y Outer brg # KB-11630Z Seal # 455860 46-72 All (Full-Floating) (H050, H052, H072) Inner brg #KD-11786-y Outer brg # KB-11630Z Seal # 2081 So they are showing all taking the same inner and outer bearings, but a different seal for the 65-66 model years, though they don't say what model they are referring to.
#140 (permalink) |
Member # 109325
I got my DRW ho72 tore down today. I was looking for numbers stamped on the r&p and didnt find anything. Trying to find the ratio so i can continue the rebuild. It has 32 teeth on the ring gear. Any were special to look for the ratio?
#141 (permalink) |
Got Drivetrain?
Member # 140133
All of mine are stamped with the ratio on the nose of the pinion. If you look at the 3rd member from the ring gear side, look at the face that is showing through the pinion support bearing.
You probably have a 4.57 set (32:7) Otherwise, count the teeth on the pinion, then divide the ring gear tooth count by the pinion tooth count to get the ratio.
#143 (permalink) | |
Member # 109325
Thanks man. Like you said, it was stamped on the inside of the ring gear. |
#145 (permalink) | |
Member # 106663
Not the best answer but I had those barrel shaped roller bearings in one end of one of mine and I swapped them out for straight bearings from another axle, because I did not like the way they could move around in the race. They looked fine and probably would work fine but I could not get past how odd they seemed and I had access to straight ones to put in anyway. |
#146 (permalink) | |
Bad Doctor
Member # 86878
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build http://www.pirate4x4.com/forum/showthread.php?t=994394 |
#148 (permalink) |
Member # 130031
I just used the Standard 9/16" 14 bolt stud for a SRW application. But I used a Hand reamer to get the diameter close. Under drilled and then cleaned it out to get as much bite from the knurls as I could on the studs.
'97 TJ -SM465, KluneV/D20, HO72/HP60, ORIs, 40" Comp Treps http://www.pirate4x4.com/forum/showt...=781656&page=3 '42 Dodge WC53 - Cummins CRD, Allison 1000, HO72s F/R, 38" Michelins http://www.pirate4x4.com/forum/tow-r...airstream.html Last edited by AlxJ64; 10-05-2009 at 01:04 PM. |
#149 (permalink) | |
Bad Doctor
Member # 86878
I have swapped the ring and pinions from 052 to 072 like previously posted without any noticeable difference.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build http://www.pirate4x4.com/forum/showthread.php?t=994394 Last edited by Odin K30; 10-05-2009 at 04:02 PM. |
#150 (permalink) |
Super Willie
Member # 19067
They? You mean both the H052 and the H072?
The earliest reference I can find for the H072 is 1946. The earliest reference I can find for the H052 is 1956.
