eaton H072 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-18-2009, 02:05 AM   #1 (permalink)
Member # 112787
eaton H072
well ive got an HO72 with 4.56's and a detroit and i found some threads on it but there are a few things i didnt get an answer to. first off do these axles have the strength to handle 40 inch + tires without bending. will the 17 spline shafts hold up to 40+ tires?? from what ive read about them theyre good but im still skeptacle about it. thanks for any help
WHEELING: THE MOST FUN YOU CAN HAVE WITH YOUR CLOTHES ON........1985 blazer 1980/82 trazer 02 LB7 2500HD 85 3500 crew cab
blazerboy85 is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 02:58 AM   #2 (permalink)
bigal1's Avatar
Member # 119174
I had one with welded spiders and 456 gears,i put disc brakes on it, just like the 14 bolts use and ran 44s on two different trucks that i had, over a course of seven years.I had no problems at all with this axle.I beat the crap out of it.I would recomend it to anyone.
bigal1 is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 05:01 AM   #3 (permalink)
Member # 86878
IMO the Eaton H052/72 axle is the best kept secret in wheeling.
Ive run them up to 44 in tires, 500HP, filled'em with mud, and just generally hammered the piss out of them. With zero failure.
More strength, ground clearance, and less weight than a 14FF.
-Vinny
[COLOR="Black"]-[/COLOR]from Elizabeth
[COLOR="Black"]Nobody cares about your rigs specs...
[/COLOR][COLOR="Lime"]"Me too" short Crew build[/COLOR]
^^ Parting Out ^^
Odin K30 is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 12:19 PM   #4 (permalink)
Member # 80208
If your worried about the shafts, you can put 14 bolt side gears and shafts in that housing. That's what I did. easy swap. Great axle. Wish I could find another one.
76 fj-40, 400sb, 465, 35's.
89 blazer, tbi 350, nv 4500, 241, 60, eaton, 5.13's, 38.5 SX's.
J-Ohlin is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 08:56 PM   #5 (permalink)
bigal1's Avatar
Member # 119174
shhhhhhh !!!
Old 03-18-2009, 09:31 PM   #6 (permalink)
Member # 112787
were you using the stock 17 splines?
Old 03-18-2009, 10:23 PM   #7 (permalink)
Member # 112787
heres pics of it. and heres the pics of what i think is a napco front for ya odin.
Old 03-18-2009, 10:37 PM   #8 (permalink)
bigal1's Avatar
Member # 119174
Yes,all stock cept for the addition of disc brakes...The last truck i had that in was a full size 1 ton chevy open 60 front, eaton rear with welded spiders and 456s 13'' of lift and 400 horse small block,I would rev wide open and dump the clutch with 44s...broke alot of drive shafts and sheared the teeth off the 60s ring gear but never a problem at all with the eaton,and I always hear people bad mouth that axle....I just and say i'll take it off your hands...
Old 03-18-2009, 10:45 PM   #9 (permalink)
Member # 112787
haha yea i think im gunna run the eaton rear with disks and 40's and ill just do a 60 up front.....does anyone have any idea what that front axle would be worth?
Old 03-18-2009, 10:49 PM   #10 (permalink)
just4cuz's Avatar
Member # 98655
Those axles would look sweet under a 57 long bed stepside I know of.
just4cuz is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 10:54 PM   #11 (permalink)
bigal1's Avatar
Member # 119174
That front axle is an interesting piece..I dont know what it is...... if it were me I would take it apart and see just what the hell I got before i sold it or bought something else..........
Old 03-19-2009, 12:22 AM   #12 (permalink)
trkklr77's Avatar
Member # 29016
it is a napco. ie: eaton with closed knuckles from what would become the d44.
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 03-19-2009, 12:50 AM   #13 (permalink)
bigal1's Avatar
Member # 119174
Thumbs up
Ah,Then I would sell it....
Old 03-19-2009, 01:48 AM   #14 (permalink)
trkklr77's Avatar
Member # 29016
to who???
not very desirable, they only hold value to the resto crowd and good luck getting anything more $100.
Old 03-19-2009, 02:49 AM   #15 (permalink)
bigal1's Avatar
Member # 119174
to who???
To who ???????? How the hell should I know......I did say that I dont know what it is.....
Old 03-19-2009, 08:36 AM   #16 (permalink)
Member # 86878
To me.....
pm sent
-Vinny
^^ Parting Out ^^
Old 03-19-2009, 09:24 PM   #17 (permalink)
noface's Avatar
Member # 87021
what model year trucks do these Eaton HO52's come from. IIRC 60's era 1 Ton chevy's?
noface is offline   Reply With Quote Quick reply to this message
Old 03-19-2009, 09:58 PM   #18 (permalink)
trkklr77's Avatar
Member # 29016
from at least 55-72.
most of the ones i have seen were in dualies.
Old 03-19-2009, 10:30 PM   #19 (permalink)
Member # 112787
mine are on a 69
Old 03-19-2009, 11:58 PM   #20 (permalink)
just4cuz's Avatar
Member # 98655
The pics are of a 69 chassis? Reason I ask is Napco did some conversions to one ton trucks into the early 70's, but they were mostly Fords. Chevy had their own factory 1/2 ton and 3/4 ton trucks starting in 1960 I believe. Front axles on all of them were closed knuckle Dana 44's up to 66 for sure and maybe a year or 2 later. Like I said those axles would be perfect for a 57 longbed stepside I know of. The nostalgia crowd would be the market for these axles. Anybody who uses their 4x4 regularly would want more readily available axles.
Old 03-20-2009, 12:19 AM   #21 (permalink)
Member # 123438
ive got one sitting in the yard . . 4.56 no locker . .ive heard alot of good about these axles and its too cool to sell. was thinkin of running it in the truck but not much for gear options . . or am i mistaken? can u run 14 bolt gear sets in these?
Hellbilly Delux is offline   Reply With Quote Quick reply to this message
Old 03-20-2009, 04:27 AM   #22 (permalink)
trkklr77's Avatar
Member # 29016
not the gears as in ring and pinion, side gears and axle shafts. i dont know if the swap will work with the 052.
Old 03-20-2009, 05:01 AM   #23 (permalink)
Member # 86878
GM used them from 1947 to 1972.
Most Ive seen have been SRW.
14 boltFF side gears and locker can be used with H052/72 axles.
Only ring and pinion ratios are 4.10 4.57 5.13 and rumor has it 5.86.
-Vinny
^^ Parting Out ^^
Old 03-20-2009, 05:04 AM   #24 (permalink)
Member # 86878
I have always used the stock 17 spline axles.
-Vinny
^^ Parting Out ^^
Old 03-20-2009, 08:48 AM   #25 (permalink)
Member # 78830
from the pic it looks like a smaller 52 comparible to a closed knuckle 44. are they 8 lug? I might be interested if it were.....maybe $100 tops though. my front & rear are 72 center, front is custom fabco......SA102 if I remember correctly. I would love another if I can find one.
BTW I know a guy that ran the ho72 in his tow trucks exclusively. licence plate reads NOS TOW, if that give an idea of how they hold up to big wheaght & abuse
69 fj40, 44boggers, 305/350/203/205, fabco front center diff, Eaton rear locked F+R
basspro is offline   Reply With Quote Quick reply to this message
