Member # 12662
Chevy k20 fuel pump question
i have a 1977 chevy k20 with 2 fuel tanks. I want to put an aftermarket fuel pump on it but it have 2 lines into the pump and 1 line out to the carb. one of the lines in is 3/8" and the other is smaller. whats the smaller line for??? do I need it to keep the two tanks??? dose anyone have a diagram of the fuel system??
Thanks Chris
1943 Flat Fender Medic Special 4.3l/th350, dual toy t-cases D44/D60, on 38 tsl's and some other cool stuff 1998 dodge cummins 4X4 sled puller [url=www.sanjuanrockcrawlers.com] San Juan Rock Crawlers[/url] |
Member # 52872
The smaller one should just be a drain back line for excess fuel not used.
Why? Do you have a high performance engine? If its just stock a stock mechanical pump will do the job just fine.
[COLOR="gray"]Horsepower is like a Condom.....I would rather have it and not need it than to need it and not have it [/COLOR] |
Member # 12662
ya the stock one was not keeping up. I want to run a summit 100 gph pump they only have 2 ports 1 in and one out. so I can just plug the smaller line then?
Member # 52872
Yah you can just plug the drain line.
skullfuckery
Member # 29016
with after market pumps you sometimes have to runa regulator, some higher end regs have a dump/return line so you are not building up to much presure between the pump and reg.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 12662
cool thanks for the help
skullfuckery
Member # 29016
what came with later k5 models?
nearly every stock pump after 73 came with a return line.
