NV4500 leaks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2009, 08:45 PM   #1 (permalink)
MuddinManny's Avatar
Member # 80610
Send a message via AIM to MuddinManny Send a message via MSN to MuddinManny Send a message via Yahoo to MuddinManny
NV4500 leaks
Hey Y'all,
Here's my situation:
I have a brand new 92-94 early style GM NV4500 4x4 version transmission. It is bolted up to a hybrid fixed yoke NP208 and has a DIY4X clocking ring in-between.
Yesterday, I started my truck for the first time with the transmission installed. Immediately, Syntorq fluid began heavily dripping from where the clocking ring meets the t-case.
I don't understand why the NV4500 would leak, so I called my builder and he explained to me that the entire adapter fills up with Syntorq. I knew that the 5th gear overdrive which is contained inside the forward area of the housing gets oiled, but I didn't think that the output shaft area after the retainer was supposed to fill up. Here's a picture of the area which I am questioning:
When I pulled the BW1356 off my core, there was no Syntorq in there. What gives? I'm having a hard time accepting this as normal. I'm not aware of the NV4500 and t-cases sharing oil.
I have found that all models, Dodge and GM, except the 4x4 GM version have rear output seals. WTF?
Please help.
Thanks,
Manny
Keep all 4 wheels down...down and dirty in the MUD!
MuddinManny is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 10:50 AM   #2 (permalink)
jeepinwilson's Avatar
Member # 34804
I ran into this with mine, different t-case but same senario and I have a seal on mine. Had to use black RTV on the clocking ring (both sides) and the studs. No leaking now.
1947 Willys
jeepinwilson is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 10:51 AM   #3 (permalink)
'Merica. Fuck Yeah!
86k30's Avatar
Member # 25703
Fluid gets thrown up in that cavity but shouldn't stay there. Did you have the Tcase in when you started the truck? The countershaft rotates all the time (I think??)in the bottom of the case, even in neutral ,just off of the parasitic drag though. So it could throw fluid up there and leak if the tcase wasn't in yet.
The facelift:
86k30 is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 02:05 PM   #4 (permalink)
Member # 46216
Send a message via AIM to shortsub
ive got a nv4500 - 205 in my cummins .... silicone that sucker thats what i did.
mine doesnt leak , well it does but thats not the point here.
the silicone works
396 forged and rollerd' [U]small block[/U], propane, 60 /14 with chromos ,th400, ord doubler , HAD 1410s f/r , full hydro, lockd 42 sxs .... all wrapped up in a glittery package
07 d max LBZ with a fatgirl on the back
shortsub is offline   Reply With Quote Quick reply to this message
