Member # 1259
when i start my K1500 up i get oil pressure at closer to 60 pounds then when driving at speed on the highway it drops to 40 pounds stopping at a red light etc drops it to 20 pounds
this just started to happen never noticed it this summer when i got the truck normal or a problem brewing?? Thanks D |
Member # 5021
A good standard to go by is 10psi for every 1000rpm minimum Also the gauge can be going south Those pressures dont sound bad at all. If you are that concerned I would install a mechanical gauge and watch it.
Member # 4737
My blazer the presure doesn't change that much but the truck I drive at work (93 3/4 ton 350 tbi) the presure seems to run about like what you discribed about 40 on freeway and 10-20 at a stop light. It's done that sents it was new.
1989 Chevy Blazer 350 V8 |
Member # 6287
dude, i noticed my trash does about the same thing and i have an old school 350. i guess as the engine warms up the oil press drops. it still runs so i dont care <IMG SRC="smilies/usa.gif" border="0">
have you taco'd a ten bolt lately? 83 chevy beast 37"boggers lock rights powered by white trash usmc will blow their shit up |
Member # 4140
Those are good oil pressure readings. No problem whatsoever.
Tim There is no accounting for taste 1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, [B][COLOR="Red"]2008[/COLOR][/B]. |
Member # 1259
I realize i will drop pressure as the oil warms up, thats why i am a little worried i never had this problem in the summer months with temps in the 90's
I just thought of a reason though I did have one of the guys at work (i'm a car salesman) change the oil he could have put 5 weight oil in this would probably account for the pressure drop due to the thinner oil |
Member # 170
So I've heard the 10 psi for every 1k rpms but when my system gets up to temp 180-190 my pressure drops to less then 10 (mech gauge) at idle and 650 rpm...it does climb quickly and I know that pressure and flow aren't the same and I have plugged the bypass to send the oil through the filter 100% and use 20w50....engine doesn't knock and have had the problem for awhile and haven't noticed any other problems....might try replacing the filter plate with the bypass unmolested....any ideas?????
Red Racer I Toyota FJ62 |
Member # 7303
This is the spec for every engine I have worked on (except Harley
):15 psi minimum at idle 45-60 psi at operating speed (2000 RPM for my BII) 75 psi max This goes for my little VW, as well as the Fair-Banks Morse deisels that are the size of my house.
All the same Buellshit to me. '04 Honda 1000RR - daily driver '59 VW - Long term toy '00 Buell X1 - #1,653 stunna '88 Ford Bronco II - Trail slut '00 Buell Blast - Power is not an option '04 Honda Shadow Aero - wife's daily driver '04 - Chrysler PT Cruiser - puppy transportation |
#12 (permalink) |
Member # 14584
If there is a change all of a sudden then something happened. The oiling system is actually more reliable than the indicating system. A cheap mechanical gauge is a good troubleshooting tool.
Here is some good info http://www.melling.com/support/bulletins/default.asp
Yes my truck is environmentally friendly. It lets most of the environment in the truck with you! |
